Question about Dell Dimension 8200 PC Desktop
Error message Fan Failure press f1
I got this message after I turned my computer off and rebooted it. I have noticed it was running slow ,it is a Dell 8200 purchased about 6 yrs ago.
  • 24 Answers
Some of those OEM systems have built in fail safe's like that to try and keep them running longer w/o failing. Just get a hold of Dell and get a replacement fan, they should send instructions on how to put it in yourself! :)
Posted on Nov 12, 2008
Dell dimension 2400 freezes up shortly after boot. I replaced cooling fan but error log shows keyboard failure.
if you see lights get on Keyboard.. your motherboard is fine.. else it is your Keyboard or Super I/o Chip that is not working..
Mar 27, 2013 | Dell Dimension 2400 PC Desktop
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
My pc dell optiex gx270 when i attach 1 hardrive in computer in start up time in black screen message 0 seek failure , boot press f1 to stup press f2 when i press f1 message not boot drive find when go to...
once in the setup (F2 at boot) turn on Caps Lock, NumLock and Scroll Lock (all 3 keyboard lights on)
Press ALT + E (system should beep once) Press ALT + F (System should beep once) Press ALT + B (System should reboot and re-detect drives)
Aug 05, 2011 | Dell Dimension 3100 PC Desktop
On my computer i have to push f1 to start it
first try to notice the message before the (press F1 to continue) message, it could be a bad component (memory, hard drive, etc...) or the time & date is not set correctly in the BIOS, this would help a LOT thank's...
Jun 25, 2011 | Dell Computers & Internet
A message says "previous fan
my dell gx 280 fan failure how i solve it'
Nov 23, 2010 | Dell OptiPlex GX280 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Hello at start up of my dell 9150 i have this message "card cage fan failure" so i press F1 and the computer work but do i have a solution to not having this message again?
Yes, you need to replace that fan and not run your computer without it working because it can cause it to overheat and then you'll have to replace a lot more than just a fan. Open up the side of your computer and see which fan is not moving when the computer is turned on but it will be the one attached to the card cage :c)
Jun 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
CPU cooling fan
Hi...you can press the F2 key to enter setup...and scroll down until the fan is highlited...hit enter and then F10 to save and exit.This tells the computer its OK.
you should have plugged the fan in the same pin port the old fan was in. Usually only 1,.
If the new fan is not from dell..it may be faster and noiser..or it may be faulty..if you bought it locally you may try to return it.
The purpose of the fan of course is to remove the hot air from the CPU to keep it from overheating. If this fan does it it is most likely ok.
Hope this helps..
Squipps
Feb 07, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
166 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
