Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Error E15 - MAchine not draining
We have a hotpoint ultima, shich will not drain, it says Error E 15 check pipes, however, we bought some cleaning tablets, which we put in, and found that, with these and a hot (95) wash it will drain, but not at 40? Any ideas? Regards Dave
  • Fakkers Nov 08, 2007
    I have exactly the same problem and it's driving me potty. Did you try this? Did it work? Water everywhere? Grateful for any thoughts you might have!
    Thanks,
    Sara
    President:
  • 1,462 Answers
Drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Posted on Mar 22, 2007
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima extra washing machine says e15 check outgoing pipes i have cleaned the pipe out and is washing to a certain point then e15 shows and starts to beep continuously
hello,
what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Aug 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Please rate my solution.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code f5
I think you mean error F05 for a Hotpoint washer.
it means the pressure switch is jammed on full, check pump is working o/k and if there is a filter, remove and clean it, see user instructions..
If still no joy, then you will have to call an engineer..
Plz rate this solution.
Thanks.
Jan 02, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
Outlet Pipe
Your machine has detected a problem with draining. The place to check is the filter located at rear of machine.To access it remove plate at bottom rear of machine & you will see a black pipe hanging vertically from the drum secured by a spring clip.The filter is in this pipe. If this is clear take off other end & check pump is not obstructed.Be aware that there will be water in these pipes so may be wise to take machine outside.Let me know if problem persists.
Nov 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
309 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
