Question about Panasonic PT-56TWD63 56 in. Rear Projection Television
Panasonic does not turn on.
TV does not turn on, the power light blinks red three times and it does not turn on. Panasonic PT-56TWD63 56 in. Rear Projection Television is the model.
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: power up
is it a constant blink, or does it blink a nummber of times in between payses? Let me know the number of blinks. Please respond to this same post so I have access to previously posted info.
Posted on Jul 01, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Posted on Oct 31, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Posted on Aug 14, 2009
welcomejee
  • 10594 Answers
SOURCE: What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Posted on Apr 18, 2010
Testimonial: "Thanks"
SD Tech
  • 14553 Answers
SOURCE: I have a Panasonic HDTV Projection Monitor model
Three blinks is short protection in this model.
98% chance one of the protect resistors around the two STK-392-110 convergence chips is bad.
Good news here----total parts cost would be under 25 dollars on EBAY. I use a seller there.
I also have start to finish, step by step instructions for this repair in this set.
They tell you everything you will need and how to do the repair.
Let me know if you want help or the instructions--I can tell you how to look to see if the protect resistors are bad.
This is a very common problem and I have fixed hundreds of these sets with this problem.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
If you need more help or want the instructions let me know, we will find a way to get them to you for free.
SD TECH
Posted on Sep 15, 2010
I have a pt-47wxc43g panasonic projection tv and when i turn it on the red light blinks three times and it does not turn on.
Three times red light blinking indicates problem of convergence output chips are bad, tv has 2 chips that need to be replaced.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you technical info OR local tv repairman will do this job for you.
Thanks.
Dec 27, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
2002 Panasonic PT-47WX52F - Power button now just blinks 3 times
thats the convergence circuits needing repair. You can repair it yourself for around 50.00 with the convergence repair kit for your model from www.tvrepairworld.com the kits contain the parts and the CD with instructions.
Mar 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
I'm having a problem with my Panasonic PT-53wx52
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Oct 30, 2008 | Panasonic PT-53WX52 53" Rear Projection...
Panasonic PT-53TW53G
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-56TWD63 56 in. Rear Projection Television Logo
50 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
