38 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Mar 25, 2009
i have a nokia 800xa it turns on then after 3 sec it turns off
Comment by Guest, posted on Mar 06, 2009
monitor goes blank
Comment by rsaindon717, posted on Jan 21, 2009
I have the same problem as you (kansasas) did you ever figure out a solution? Im thinking its the power cord....
Comment by z_carey, posted on Jan 07, 2009
My monitor has been shaky for about six months. Today it started shaking really bad and just went black and will not return to normal until I have turned it off for a while. Even then it goes out after a few minutes.
I am running two monitors with dual video cards and my tower and monitors are dell. My xps is about two years old
Thanks so much
Help
Zach
Comment by Guest, posted on Jan 04, 2009
I got the same problem with benq monitor. I followed soln 7 which is to unplug and plug the power back. Everything back to normal :)
Comment by billy2kool, posted on Dec 21, 2008
I have check the power supply and all the capsitors look good, no indications of burst or anything so how will i know which on is bad or not
Comment by billy2kool, posted on Dec 17, 2008
i have a V7 20 inch monitor and when i turn it on it stays on for a sec and then you hear a fuzzy sound and goes black and the blue light goes orange
Comment by Guest, posted on Dec 14, 2008
i have the same prob...
Comment by Narthalion, posted on Dec 09, 2008
Mine does the same thing, but if I turn it on and off about 5 or 6 times it stays on then after that, so would it still be the inverter board?
Comment by kevkat8, posted on Nov 29, 2008
I have a Dell 8600. When I power it on the LCD flashes for 1/4 sec and goes black. I am going to replace the inverter and see if that is the problem
kevkat8
Comment by Guest, posted on Nov 21, 2008
Exactly the same problem.
Comment by Guest, posted on Oct 14, 2008
This happens to me, but when you look really close and hard, you can see still barely see it
Comment by Guest, posted on Sep 05, 2008
I have same problem like "electronix" in four monitors.
Comment by Guest, posted on Aug 28, 2008
My monitor goes blank and the green light stays on.
Comment by electronix, posted on Aug 09, 2008
IBM LCD monitor model 6734-AB1 goes off after few seconds, while is showing the picture is correct but the screen goes blank after fesec (1-2 sec). If I turn off and back on the monitor the problem repeats itself.
Comment by tom_hallibur, posted on Jul 12, 2008
I have a problem that has been intermittent, but now occurs all the time, with my LCD monitor (AOS LM928, 19"). The screen goes blank on startup after less than 1 second on each display (motherboard, bios, XP, "welcome", desktop). The green monitor light stays on and the display will return, but just for the same period, whenever I turn off the monitor then turn it back on again. I have a Radeon X700 graphics card.
Comment by digno, posted on Jun 26, 2008
when i turn it on my monitor i only see is all white then turn in black help me what to do??
Comment by Guest, posted on Jun 25, 2008
My monitor flashes xp for about 1 second and then goes black although the button is still green.
Comment by Guest, posted on May 21, 2008
Flat panel monitor goes dark/black every 30 or 40 seconds.
If I turn it off and back on it works for about 30 to 40 seconds.
Now, as I'm using the keyboard writing this description, it stays on and works perfectly. I realize it's a settings thing but what?
As long as the keyboard or mouse are active the monitor works.
If I'm inactive it goes dark. Any suggestions?
Comment by frstdinCov, posted on May 17, 2008
The 1800FP monitor will not come on at startup. I sometimes turn the computer on and off 10X to get the monitor to finally come on.
Comment by spook1991, posted on Apr 20, 2008
I have a SVA VR-17s and when I power it on, it flicks on briefly then it goes black while the power light stays on, also while doing this it makes some weird humming noise. What is this?
Comment by donny77, posted on Apr 19, 2008
I have a Dell e771p Monitor and over the last few weeks I could not turn it off at the Switch, the led light would just remain on.
I decided yesterday to pull the cover off and see if I could find the problem.
It appeared that the Push Button was not touching the switch connector.
I turned the retangle plastic spring loaded connecter over so that the contact would be made.
I put it all back together and now the Monitor wont stay on, so I wacked a piece of sticky tape over the on/off button to hold it in.
Not the best way to fix it but it works at present until I think of something else.
Regards
Don
Comment by skitzoyd, posted on Mar 07, 2008
I have the same problem, monitor goes black after turning on. I can push the input button on the side of the monitor and the screen comes back on for a second. I can run programs still but monitor goes back off again. I can do this all day but monitor just won't stay on.
Comment by chrisosborn, posted on Mar 03, 2008
same problem with Dell E153FPT
Comment by straight, posted on Feb 12, 2008
Monitor goes blank less than a second after turning on. problem,
Comment by Guest, posted on Feb 07, 2008
exact problem. I replaced my monitor thinking it was that, needed replaced anyways. That didnt solve the problem. I replaced the video card and still doing it. Im assuming its either a motherboard or powersupply problem.
Comment by Guest, posted on Dec 27, 2007
i have a mac book and my screen is very dark, all u can see is little outlines and shadows of all the icons, what can i do?
Comment by bomberbob, posted on Dec 21, 2007
I have a Spectre DCL LCD model S1702D. It quit working, would keep trying to restart, but no video. After reading this thread, I opened the back, and replaced one bulging capacitor. Earlier posts said to replace the whole bank, I only changed the one obvious bad cap.
This is your problem: Original cap was a 470 microfarad, 25 volt part. Since these monitors appear to be dying like flies, either they bought cheap parts, or the design is poor, and the parts are over stressed. I replaced my bad cap with a 470 microfarad cap (same capacitance value), but I put in a 50 volt part. The 50 volt part was too big, so I cut a small hole in the EMI shield for the cap to stick up through. There is another 25 volt cap in parallel, so it might be the next cap to blow. I have another 50 volt part to put in if this happens. If you put in the same part (25 volt), and the design is poor, you will blow those out too. you need to uprate to a more robust cap.
Word to the wise. With 50 volt parts, this thing will be bulletproof.
Comment by Want2repair, posted on Nov 27, 2007
Dell 19" monitor powers on fine displays
image for a few seconds and then no image. Power light stays green no flashing. power it down and then back up shows and image and then goes blank again. same thing no matter how many times you trun it off and on.
Comment by Guest, posted on Nov 25, 2007
Comment by BECCA25007, posted on Nov 25, 2007
EXACT SAME PROBLEM
Comment by Guest, posted on Nov 20, 2007
Monitor comes on 4 a half sec then black I know its not the bios or card or resolution it is the monitor I heard something about internal power inverter it's a 17 inch DCL model no. s1702d
Comment by Guest, posted on Nov 14, 2007
absoluety same as kansasas
