Question about Moultrie MFH-DGS-100 Digital Camera
BATTERY FOR THIS MODLE WILL NOT HOLD A CHARGE WHY?
I BOUGHT IT BRAND NEW AND HAVE NOT BEEN ABLE TO USE IT
BECAUSE OF THE BATTERY. THE MODLE IS MOULTRIE DGW-100
    Problem Solver:
  • 6 Answers
Try a differnt battery. Some batteries are bad right off the shelf. Keep the camera out of direct sunlight as this seems to drain my batteries faster than anything. Write back with more details of your problem if this doesn't help.
Posted on Nov 29, 2008
DMC-FZ18 doesn't hold charge
Hi! we bought two brand new battery's on eBay for less then $10bucks + free shipping! might want to poke around eBay?
Apr 21, 2013 | Panasonic Lumix DMC-FZ18 Digital Camera
Brand new battery won't hold charge. Camera is three years old. I bought an extra battery when I bought the camera. They both seemed to go bad at the same time, so I recently bought two new lithium...
if this happens even to new batteries, it may no longer be an issue with the batteries, but it can be an issue with the camera itself. check the maximum number of shots that the camera can take with the batteries per its specification. if it should produce more, it would be a good ide ato check with Canon to have the camera checked.
Sep 06, 2010 | Canon PowerShot SD800 IS / IXUS 850 IS...
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
My dscs85 won't hold a charge. Bought a EMpire
Go to menus and check for the kind of battery you have as against what is listed in your menus. Make sure it is set correctly.
Also you can try to set all menus to default, or reset all or something like that.
Oct 27, 2009 | Sony Cyber-Shot DSC-S85 Digital Camera
Battery?, wiring??
If your Alternator didn't charging the battery, even though you brand new battery will not last. So there is two possible cause, 1) Your Alternator is not functioning. 2) there is a wiring problem that causing your battery to discharge easily, but you check it after you switch off the key remove the battery negative terminal then touch it back to batt term. and see if there is little blue spark, if does your wiring system got problem. If not, so your Alternator do not charge the battery.
Jun 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My 91 toyota celica gt will not hold a charge.
the only reason that a battery will go flat is if its not getting a charge from the alternator, the brand new battery you purchased might be a little faulty but i cant see it. has your ride got abnormal stereo in it or aything unusual such as lots of dvd players n such as these can make it so your standard alternator cant charge quick enough before releasing to the equipment.
Feb 27, 2009 | 2006 Toyota Celica
New bright 19.2v nicd battery problem
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Jan 17, 2009 | New Bright Remote Control Toyota FJ...
Moultrie MFH-DGS-100 Digital Camera Logo
311 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Steve
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
