Question about JVC GM-V42UG 42 in. Plasma EDTV
Capcitors c5093,c5094,c5095 are blown on the Samsung lj41-02016a
Need capacitor value for c5903-5905
  • jim_worthen Nov 12, 2008
    the blown capacitors are C5093, C5094, and C5095 on a Samsung LJ1-02016A PCB of a JVC model GM-V42UG...all the caps are the same. This is what is on the caps: T L 335K
    250U
    Genius:
  • 1,550 Answers
C 5903 - .0047Mf
C 5905 - 470Mf
Posted on Nov 12, 2008
  • 1 more comment
  • SAM ANDERSON Nov 12, 2008
    C 5904 - 0.1Uf
    C 5904 - 0.1Mf
    Dont confuse with previous post
    All are in micro farad
    C 5903 - .0047Mf
    C 5904 - 0.1Mf
    C 5905 - 470Mf
    I am bit confused with your question in first post you mentioned
    need capacitor value for c5903-5905
    In second post
    For the second post this are value
    C5093- 50uf
    C5094 -25uf
    C5095 -10uf
    Brigadier General:
  • 3,614 Answers
May i know please the exact model of your unit. and on which board is this capacitor is..
Samsung fried cp803 capacitor what value do I replace it with
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Circuit diagrams of many popular brand TVs and other devices are given. You can fetch details there.
Nov 30, 2016 | Samsung Televison & Video
My Samsung 42 inch does not switch on but the red standby light is on.
The most likely problem is the power supply has leaking or bad capacitors. Look at the power supply board and see if there are any leaking(oily looking) or bulging capcitors. Simply replace them with same value capcitors and you should be ready to go.
Oct 31, 2016 | Samsung Televison & Video
Model XP300. Where can I get a schematic diagram and service manual?
You should be able to read the value of the capacitor on the side
Can you confirm if it is Flat Panel TV from Samsung ? because I find an Epson and Buick
Mar 24, 2016 | Samson Audio Players & Recorders
HOT transistor TT 2222burn after second replace. TV Samsung Model CS-21Z45MJ
Hello
Before replacing an other one, replace the freewheeling capacitor, the capcitor fitted between the collector of the 2222 and earth; usually of a value of 3500pf 2000VDC, some times this value may differ from set to set. If this capacitor has opened of developed in value, the result will be the failure of the horizontal output transistor, at switch ON itself. The second reason is the short in horizontal yoke windings. Even one winding get shorted, it will cause to a heavy load flyback transormer which in turn to 2222 failure. The last reason for this fault is defective Line Output Transformer itsef. Check these three.
Before proceeding, desolder out the horizontal output transistor 2222 fro circuit, and measure the frequency at the collector point of horizontal driver transistor. It should be around 15625HZ [may differ a little], with no signal. If this frequency is found higher than normal, The main IC jungle should be suspected.
Anyway, go forward after checking this frequency. OK.
Jun 10, 2011 | Televison & Video
Horizontal black line running entire screen an 4 more lines running vertical
Hello
This type of fault in Plasma TVs are of power supply regulator capacitors. If any one of these DC capacitors, go low in rated value, proper smoothin of DC power does not occur. and black bars across the screen fro top to bottom will be the result. Just check for any capcitors of it power retulator side for bulged out or leaky. You have to open the TV to see whethere there is any of them is damaged. OK.
Jan 30, 2011 | Samsung 50 in. Plasma TV
What Uf & voltage capacitor do i need for my samsung le40r88bdx xeu 40"???
the defective caps in general will be blown upwards there heads will not be flat the value will be indicated on the defective capaciter you must respect polarity .
Jun 09, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Will not turn on just clicks and clicks,
take the back of the tv off there is probally 4 blown capacitors on the board on the left,change the 4 capacitors you can tell there blown they will be bulging. I had the same problem, changed the capacitors and tv works fine
Dec 29, 2009 | Samsung LN-S4051D 40 in. LCD Television
Wont turn on right away
common problem with this one it is a bad capcitor in the power board the can shaped capacitor will have a domed top from venting the value of the device is written on the side you could or have someone replaced the part and you should be all set
Nov 30, 2009 | Samsung LN46A650 46 in. LCD HDTV
Need capacitor values on a Samsung Y-sustain PCB
That value is 3300000pF or 3.3uF (335) with 5% (K) and 250 volts ratings.
Nov 12, 2008 | JVC GM-V42UG 42 in. Plasma EDTV
JVC GM-V42UG 42 in. Plasma EDTV Logo
480 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
