Question about Inland ProSound 2000 Computer Speakers
Quiet, low quality sound from one speaker, static from both
Whenever I plug these speakers into my sound card, I get a strong static sound from both of them, mostly from the left one. While I do get a bit of very low quality audio from the left speaker, this is drowned out by the static. Any ideas?
Take your fist and cram it up your ***.
Posted on Feb 16, 2009
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Hello, i have phillips 460 5.1 speakers.. the sub is buzzing/humming REALLY loud.. it does it every now and again.. will start of quiet, then gradually get louder. they are a few years old now,...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
May 31, 2011 | Philips MMS 460 Computer Speakers
My speakers work but there is a lot of static. Can you help?
wrong connection in the back of the computer? it could also be low quality sound card try plugging them into your music player see if static is still there than its the AMP on the speakers if not its crappy sound card. good luck you can try USB sound card for around 20$ on amazon.com
Mar 02, 2011 | Bose Companion 2 Computer Speakers
Only my left speaker is working very quiet and the other don't work.
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
don
Feb 17, 2011 | Logitech Z323 2 Speakers
Left Speaker Jack only produces static
Hi!
That is probably happened to an aging speaker.
Consider buying a new one or try to rewire the coil inside the speaker magnet.
Jun 01, 2010 | Bose Companion III Computer Speakers
Buzzing static sound in speaker
Static can be caused by a few things.
Does the static persist if you unplug the audio cable from your computer?
If so, the static is being caused by the amplifier built in to your speakers.
If not, the static is probably caused by interference on your sound card. Try plugging the speakers in to a portable media player. You might need to replace the sound card in your computer.
May 13, 2010 | Bose Companion 3 Series II Multimedia...
Blippy Sound
Sounds like the cords that are going into the PC/system have static. Remove the cords from the speakers and simply put your finger around the jacks to remove static. Push the cords and the jacks back in and switch on the speakers. Then twist the volume control, turning it up loud and then low, then loud and low again. That should cure the problem as it removes static that gets built up over time. Either that or your speakers could well be damaged.
Mar 28, 2009 | Altec Lansing VS4121 Speaker
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Acer Aspire 5630 - Low speaker volume, poor quality, OS=Vista
It's likely that the speakers are blown out if it's quiet and making a crackling sound. To fix that, the speakers can be replaced or you can use external speakers.
Mar 23, 2008 | Acer Aspire 5630 Notebook
Motherboard sound and old speakers
what really matters is the quality of the usb speakers. check specifications such as wattage first and find reviews if possible. however usb speakers will probably not come close to separate speakers. i'd recommend buying a cheap sound card ($20 or so). these work great overall. $20 spent on a sound card will be a better trade off than $20 spent on speakers. just use your old speakers with the new sound card and you'll have plenty of power. after this i'd recommend headphones as they work great in this case. finally moving the sound card would probably work fine, but i have doubts.
hopefully that helped
Dec 30, 2007 | Dell - 0089D Sound Card
Inland ProSound 2000 Computer Speakers Logo
814 people viewed this question
Top Inland Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Inland Audio Player and Recorder Expert? Answer questions, earn points and help others
