Question about Sony VAIO VGN-FS640W Notebook
EarPhone out not working
I have a sony vaio VGN SZ483N and the audio out for earphone is not working all the time. In some days it works, but most of the time, I get no sound when I plug earphones. How can I fix this problem? Thanks.
  • undrak007 Feb 06, 2009
    i have the same problem with fw140E
My vaio van sz483N will not start following a hard drive replacement?
The HDD has not been placed correctly leading to a short circuit so the laptop does not switch-on . Remove the HDD and power-on the laptop if it switches on then need to check the HDD .
Jun 17, 2015 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
My sony vaio vpceb24en e series is having a speaker problem, the speaker is not playing any sound in the normal case but if we plug in to earphones it functions smoothly
Buy some contact cleaner and flush the ear plug, and push the head phone jack in and out a few times, and repeat 2 or 3 times hopefully that will return the sound through the speakers.
Mar 11, 2012 | Sony VAIO Computers & Internet
Usb port are not working. need to install driver. model sony vaio VGN-SZ483N
If you can get the laptop online, then go to the Sony website ( click here ). You should be able to download the correct driver. If your laptop won't go online, you may have to burn the drivers to a disk in order to install them.
Jul 31, 2011 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
I've connected the minijack from the laptop to the phono slots red and white on my tv but there is no sound. Could you help me please
Often there is NOT enough output to drive the TV's audio amplifier directly from the earphone's port. You will need a small Pre-amplifier, in between the two, You should also try your "Line Out" as that puts out more signal, than the earphone jack. If that still will not drive it, then toy will need a pre-amp, Radio Shack, or the like will have them. Also ensure your Volume is set high.
Feb 26, 2010 | Sony VAIO VGN-N130G/W Notebook
I got same clacking noise my vaio cs17g/w so pls help to sort this out thanks
the clacking noise could be coming from the fan blades touching the main frame .
have a look and see if the cooling fan is rotating properly and not making noises
Oct 01, 2009 | Sony VAIO VGN-CS110E/W NoteBook
Not able to connect to (sense) LCD projector
make sure you have all the latest and updated drivers installed for windows XP.
Jul 02, 2009 | Sony VAIO VGN-FE880E/H Notebook
Right part of the earphone is not working
THE RIGHT SPEAKER OF YOUR EARPHONE HAVE TO BE CHANGED
Aug 08, 2008 | Radio Communications
Sony VAIO VGN-FS640W Notebook Logo
82 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
