Question about HP PSC 1600 InkJet Printer
Print is Smudged
I put a new black ink cartridge in my HP Office Jet J 6480 All In One printer and the print is smudged. This is the first time that I have had to replace the cartridge as the printer is fairly new.
  • 191 Answers
You may try
1) clean the cartridge nozzles with dry soft paper
2) clean the cartridge carriage down side surface there might be bled ink.
3) check the cartridge up side there is the lable cover the ink refill hole is ok, no any lable stick there you need put stick lable there.
Posted on Feb 08, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
Canon printer is printing with smudged text, how do I resolve it?
Most Canon printers have a clean print heads function. Search the menus until you find it. This is maintenance you should perform on your printer routinely. Once you do that and it still is smudged, remove the ink cartridges and clean the end of them carefully (you don't want ink to go everywhere). Look where the cartridge(s) connect to the print head. They may be dirty as well and need to be cleaned. Go to the following website and they go into specifics on how to clean your printer:
How to Clean Clogged Printer Heads
Nov 15, 2017 | Canon Office Equipment & Supplies
We have an hp Laser Jet 1300 printer. Approx 2" from left there is a smudge line from top of printed document to the bottom where the ink in the letters is scraped off and there is ink smudged onto...
First of all..do u refill ur toner?? if so i advise u to get a new original one and refill that..do refill the same toner for more than 3 times. Secondly, How old is ur printer and how many pages do u print weekly..or u be better off buying a new one...Finally, I think the problem is with the heated rubber rollers that are not melting the charged toner particles causing it to smudge. try cleaning the printer by removing any dust...i prefer that u try it out with a new toner and see if u have a same problem.
May 05, 2011 | HP LaserJet 1300 Printer
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
Printer appears to be printing but nothing prints on paper
if your printing off a pc you need to hit print to activate
May 01, 2010 | Canon PIXMA iP90 Mobile Printer
HP Laser Jet 4200 PCL 5 printer is printing a black smudged line down the side. I changed the toner?not helping.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 10, 2010 | HP LaserJet 4200tn Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Laser jet produces printouts that are smudged and dark
Remove the toner cartridge and use a soft cloth to wipe the photo drum clean of toner. Put it back and try again, if you still get bad prints, then you need a new toner cartridge.
Apr 01, 2009 | HP LaserJet 1200 Printer
Smudged Printing
change ink cartdidge then try. check also paper jam.
if still problem then change ink cartridge then check.
Jan 05, 2009 | HP LaserJet 2100 Printer
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Blank pages printing out/or smudged pages(new cartridge)
u have to take printer service center becase in your printer has a gare problem thats y he take more 2 or 3 pages one time or its clibatition is missed so u take your prinetr to printer repaire & solve this problem
Feb 26, 2008 | Lexmark Z615 InkJet Printer
HP PSC 1600 InkJet Printer Logo
228 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
