Question about Danby DDW1805W Designer Series Free-Standing Dishwasher
Leaking washing machine
When I run my washing machine there is water coming from the bottom .I don't believe that it is a hose,but cannot be sure
  • newmanbob Jan 13, 2009
    leaks from bottom
  • Anonymous Mar 22, 2014
    how do we get in the machine to check the hoses
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Why water is leaking from bottom of the washing machine
it easy .look in and wach the falling drops coming from the inlet water or from the drainage hose and pump.Whatever it is u can handle it.
Jun 24, 2015 | Candy Washing Machines
Have a maytag neptune washer is taking in water but throwing the water back out the hose and not washing it just started today before it would not spin but washed and clothes would come out very very
Too may things could be wrong with it, with out actually seeing it , it would be hard to diagnose this problem..
I believe those are computer controlled.
so it could be a computer problem.
make sure discharge hose is above level of machine, meaning if your hose needs to be vertical to the machine or the water will flow right out. The pump should not be running while the machine is filling. If it is, then that would also indicate a computer problem.
Nov 26, 2014 | Maytag Washing Machines
LGwm230 poured water all over the floor. IE error code.
It sounds like a hose from the drain pump has come ratcheted.
First of all, make sure you unplug the machine until the problem is sorted - electricity and water don't mix well.
If it is out of warranty, and you are confident with technical tasks, then make sure the machine is UNPLUGGED, and remove the rear (or top on some machines).
Inspect the hoses inside the machine, and look for any ruptured or unplugged hoses.
If a hose is unplugged, it may just need the hose clamp tightened harder, or a better hose clamp put on it...
Oct 20, 2012 | LG WM2301HW Front Load Washer
How do you take the back off the machine?
You don't, The front sides and top come off as 1 piece. Under the control panel there are 2 clips that you pop off,ddisconnect the door lid switch plug. lean the cabnet foward,( take notice of how the bottom sits on the base) and lift off the cabnet. When you put it back make sure that the water level hose didnt come off, you have water all over the floor. Good Luck
Sep 24, 2011 | Roper RAS8445KQ Top Load Washer
Water is leaking from Bosch washing machine WFL2060UC. Checked the hose connections. Lots of water comes out of drain hose after one cycle and water is pooled in the pump (place where the cap is next to...
Bosch washing machine WFL2060UC This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 13, 2011 | Bosch Axxis WFL 2060 Front Load Washer
WAter leaking out of the bottom only during a large load
Look under bottom may be a hose or pump leaking Look around the hot/cold water inlets hoses May be coming from them and not the machine and running under the machine unplug it be safe
Mar 18, 2011 | Washing Machines
Ge front loader leaks when filling
Leaks are probably going to come from one of 4 places:
  1. Door gasket: water should run down the face of the washer from the lowest point of the door.
  2. Water connectors: left rear of machine
  3. Soap drawer: water running down front of machine from the upper left-hand side
  4. Discharge pump and hoses: Right side.
Rear right would probably indicate a discharge hose leak. Front right would most likely be the discharge pump and/or connectors to it. Here's a diagram:
If you don't see any of the easily visible leaks (door, soap dispenser, connectors), try to
pop off the front access panel by removing the 3 bottom screws. Once removed try to determine where the leak is originating from...then we can troubleshoot more. If you find this advice helpful, please don't forget to rate me -- trying to get my Guru level so I can offer premium support
Jun 23, 2010 | General Electric WCVH6800J Front Load...
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
Danby DDW1805W Designer Series Free-Standing Dishwasher Logo
448 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
