Question about JVC KD-SX770 CD Player
Headunit power problems
I am installing a headunit at home and once the power is supposedly hooked up i turn the key on and all the headunit says is goodbye and turns off or doesnt even do that what should i do to fix this?
  • dobbyville11 Nov 13, 2008
    yea thanks i found wat was wrong i had the memory and the power the wrong way round and found that there was an exposed wire inside the dash short circuiting everything.
    Scholar:
  • 120 Answers
Hello dobbyville11,
It might be a few things but here is what i would check 1st, pull out the head unit make sure all the wires are pushed in all the way. The second thing i would suggest is checking the connection to the battery and ensure that the ternimals are clean and a good connection is available.
If there is something else it might be that you hold down a button while it starts, I know of some headunits that need this.
Please post what you do and how you did it. I look forward to your post.
Posted on Nov 12, 2008
  • Eeeeeeeeeekz Nov 13, 2008
    oh awesome i'm glad you got it.
    please post if you have another problem or question.
Hooked the stereo up and got power to but no sound coming out speakers but i try home speaker it work so what did i do wrong ?
if im understanding correctly what you wrote. you hooked up the headunit to the car and no sound from speakers, then you hooked up a single house speaker up and that speaker works fine. the Ohms on the car speakers might be too high, but most likely sounds like the wires to the speakers are bad.
Nov 21, 2013 | Cars & Trucks
I have a 95 nissan maxima i am trying to replace stock radio(bose) w/a new cd player but once its hooked up im not hearing any sound? whats wrong with it?
Most Bose car stereos have an external amplifier. You will need to see if that is the case on your factory setup and remove the amplifier. Then hook the new headunit straight to the speakers.
May 30, 2011 | Car Audio & Video
Help: pioneer headunit install into a ford corsair 1990.
This is tough, You need to find one that gives continuity through it when the keys are off, and on. These are the positive wires which is your constant, and accessory. The constant is always powered so when the key is turned off, it's purpose of giving power to the stereo for memory(stations,clock,presets) will work. The accessory as we now know only turns on with the key turned. Finally the ground is a negative, and must not touch the previously mentioned wires. Test for continuity against metal, and probe the suspected ground wire for continuity.
Once these wires are correct, splice them together and the radio will turn on. Now you have the painful process of hooking up one speaker wire,(from stereo) and touching the other wire same color to the other wires in your car to make the speaker work, the more you get the faster it goes as you will weed out incorrect wires since you already have some that work. Once you know a set of 2 wires works for a speaker, make sure it is the correct speaker location, as white and gray are front speakers, and the green and purple are rear speakers. This is longer than knowing the colors, but once completed, you can label the wires and have them known for future technicalities.
sorry your car was not on my wiring list, so no info.
Any questions feel free to ask!
xxsodasipperxx@yahoo.com
Nov 13, 2009 | Car Audio & Video
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Mar 25, 2009 | Panasonic CQ-C1303U CD Player
Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Jan 22, 2008 | Audiovox BA100 Car Subwoofer
Alpine 9881 cd will not play sound
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Jan 04, 2008 | Alpine CDE-9881 CD Player
JVC KD-SX770 CD Player Logo
183 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
