Question about Apple iPod nano
CheckMark On My 1-Gig Nano
When I turn on my iPod Nano, I get a screen that says 'Disk Mode' at the top with a black checkmark displayed in the middle, and a message at the bottom that says 'Ok to disconnect': the problem is that my Nano is not connected. Nothing I do corrects the problem. The Nano is frozen on this screen. I tried holding down the 'Menu' button for 10 seconds... nothing; tried holding down the center button for 10 seconds... nothing; did the same thing for the other 3 buttons... still no changes. I have tried charging the nono by connecting to the PC... that works fine. But the screen that says 'Disk Mode' at the top with the black checkmark displayed in the middle, and the message at the bottom that says 'Ok to disconnect' is still there and the Nano is not responding. Does anyone have any suggestions on what I can do? CheckMark.
  • michelem558 Nov 26, 2008
    my ipod nano is frozen on disk mode. i tried holding down all the buttons together but nothing works.
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Posted on Nov 15, 2006
SOURCE:
I forgot my admin password for my Dell C1765nfw Color MFP web interface. I changed it from the admin default, but do not remember the pwd. How do I reset it
You could try performing a hard reset. Keep in mind that this will reset ALL settings. Admin password should then be back at the default, which is admin.
Clear NVRAM from Tech Mode
  • Turn off the printer.
  • Turn on the power while holding down Left arrow,Right arrow, and Menu buttons.
  • Release these keys when "CE Mode" and "Password" is displayed.
  • Press Up arrow key twice and press the checkmark.
  • "CE Mode", "Printer" and "FAX/Scanner" are displayed. (Entered the CE Diag. mode.)
  • Press the checkmark key to select "Printer".
  • Press Down button to "Installation Set" and press the checkmark key to select.
  • Press Down button to "Clear All NVM".
  • Press the checkmark key twice to execute the test.
  • Power cycle the printer to return to the regular operating mode.
May 23, 2017 | Dell Computers & Internet
Hp desktjet printer won't work after installing refilled cartraige hp 4200
follow any of these to reset it and will work
http://tricks-collections.com/reset-hp-laserjet-4100mfp-4101mfp-4200-4300-4250-4350-9000/
or
1. Turn the product off.
2. Turn the product on.
3. Press and hold down the checkmark (Select) button while the memory is counting. The memory starts counting at 000MB immediately after you turn the power on.
4. Continue to hold down the checkmark (Select) button until all three LEDs are illuminated.
5. Release the checkmark (Select) button.
6. Press the up arrow (Navigation) button until the message New Maintenance Kit appears on the control panel display.
7. Press the checkmark button once.
the check mark is the v like sign ..
Sep 02, 2010 | HP Office Equipment & Supplies
How do i turn off the fax confirmation print
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
Aug 12, 2009 | Office Equipment & Supplies
I woke up this morning and noticed my IPOD nano silver 2GB displaying a disk mode pn th top of the screen with a huge checkmark in the middle of the screen and the phrase ok to disconnect on the bottom of...
Reset Ipod.
Make sure power switch is on.
Press and hold center button.
next press and hold "menu" on the ring.
When a Apple logo appears on the screen let the buttons go.
Should take just a few seconds.
May 04, 2009 | Apple iPod nano
Nano Ipod stuck in disk mode:
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Jan 31, 2009 | Apple iPod nano
My iPod is being rediculous.
Hi! I think there is a virus in your iPod. Check your ipod with an antivirus when it is in diskmode. Then you need to open itunes and restore your ipod and will restore it to factory settings.
And if it doesn't work then Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect.
After doing this open latest version of itunes and then restore your ipod to factory settings by selecting it from itunes.
Dec 29, 2008 | Apple iPod nano MP3 Player
My nano hang!
If your ipod just hangs, have you tried doing a reset by holding the menu and middle buttons?
If that doesn't work, before you connect it to your laptop, make sure that you have the latest iTunes loaded on your laptop.
Hold the menu and middle buttons until the screen goes black and then quickly hold the middle and play/pause button until you see a checkmark and the words disk mode. Now connect it to your computer and do a restore.
If it doesn't check the connector at the bottom. You may have some bent pins in the connector at the bottom. Unfortunately, that will cause communication problems with the computer and ipod. Hope that helps.
Oct 28, 2008 | Apple iPod nano
What generation nano do I have?
I don't know it by model number but the generation are easy to define.
A first generation nano is either black or white.  It is made out of the same material as a standard Ipod at the time.  Comes in 1 gig and 2 gig only
A second generation nano is multi colored and made from a metal case.  Similar in design to a mini.  The edges are round as well. comes in 2 gig and 4 gig.
A third generation nano is a different size than 1 and 2.  it has a bigger screen on it.  Can play videos as well.  Comes in 2 gig, 4 gig, and 8 gig as well.
Sep 09, 2008 | Apple iPod nano
16 gig fm ipod nano
There is no 16 gig ipod nano
May 27, 2008 | Apple iPod nano 3rd Generation
IPOD NANO 4 GIG
Hopefully your ipod is still under warranty, because this is indicative of a hardware problem.
You could try to force it into disk mode and do a restore, if that doesn't work then it needs to be sent in for repair.
http://docs.info.apple.com/article.html?artnum=61771
Jan 26, 2008 | Apple iPod nano
Apple iPod nano Logo
495 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
