Question about Sharp R-1200 Microwave Oven
Timer Disply Fuzzy
This is around 3 years old and the timer disply on door is fuzzy, I believe this is a LCD. Will power outages cause this? How can I remove the door to have this service? Or is there a fix for this problem? I tried unplugging to reset and nothing, just seems to be getting worse.
  • Mark Carchidi
    Mark Carchidi Nov 11, 2006
    Microwavesvc, Thanx for this information, i'll call a local Sharp service, I checked the warranty on this model and it say's it good for 6-7 years. Can't find my proof of purchase, i'll just see what they want to do. If it's going to cost me i'll send it to you.
    Thank you,
    Mark
  • Sharp Master
  • 9,098 Answers
In my professional opinion, power outages can kick a failing or weak unit over the edge, so to speak, but the primary causes of these display failures are the design and manufacturing techniques. We regularly remedy and repair these very units nationwide for $32.50, and our proprietary fixes make them better than new in my opinion, with the aim of not only fixing the problem, but preventing them from recurring. When we repair them, we have folks send us the outer door panel with built-in keypad & display assembly, the power board, and the connecting cable. Thay way we can power and test the unit as an assembly. It's better to separate the door panels instead of removing the door. I have attached a drawing to show how. If you remove the door instead of just taking off the outer panel, the microwave will have to be tested for microwave leakage, which can occur if you haven't reassembled the door with all the hardware in the exact same position as it was. So rest assured this can be economically fixed.
Posted on Nov 11, 2006
  • William Miller
    William Miller Nov 11, 2006
    I have a text file with critical safety information I would suggest you read prior to disassembly.
    You can find it with a search on Yahoo.com for "microwave safety.txt".
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 10, 2014 | Microwave Ovens
No power dead
power outages cause power surges and will damage electronic control boards. I suggest replacing the Control board and checking the interlocking door switches. Whilst inside the microwave check the magnetron for discoloration around the magnetron horn or gun as it were. If it don't look clean and new, otherwise burnt it's bad !
Feb 06, 2014 | Sharp Microwave Ovens
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Microwave panel is on, timer works, but no turning or heating. unit is 3 years old
Bottom door switch or mount.
See this file, and the DMT2420 manuals here and here.
You can order Dacor parts by part number from the Pros here.
Aug 14, 2011 | Dacor DMT2420SS Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
My Emerson microwave is about 2 years old. I washed it just like I do every week and the power went out on it.
you mean it want power up or want work when you press the star buttom?
1. check the fuse if no power.
2. If it doesn't work when closing the door after setting timer it is the micro switch that the metal lach hits when the door close.
3. unpluge the micro wave unscew the scews to the cover of the microwave remove the cover. up front by the door you will see the micro switch maybe (brown,black,white,red/white ) what ever color it is disconet it take it to the hardware store buy a new one and replace it,themreasemble your micro wave.
Oct 30, 2010 | Emerson Microwave Ovens
I bought my gourmet wave dec.2007. i believed that this microwave would have lasted at least 5 years,now the timer goes down but it is not heating what's put in.cant afford another.what can i do?EM031ESB
Chances are you have a bad door switch or mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad or otherwise turning off the timer first.
You or someone you know can see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
Jan 09, 2010 | Microwave Ovens
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Disply goes blank
The problem is most likely a burnt, loose, or cold solder connection on the control board. Most likely at the low-voltage transformer that supplies power the board itself. Carefully resoldering any suspect connections in this area should solve the problem. Be careful not to get too much solder on the connections that could short one to another.
Nov 03, 2007 | Panasonic NN-S753 Microwave Oven
LCD Display not working, everything else is
If microwave works even if lcd is out then a 100% that the microprocessor is working. Try to check the lcd driver for any loose connections, the bus cable linking the board to the lcd disply for any breaks or try replacing the lcd itself.
Feb 18, 2007 | Kenmore 63252 Microwave Oven
Sharp R-1200 Microwave Oven Logo
156 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
