Printer on;y prints in blue, how do you change it back to normal?
  • William Nabaza
    William Nabaza May 11, 2010
    see if all other printer cartridge have still ink on them
  • 507 Answers
Just replace the empty cartridges
Posted on Nov 13, 2008
Most cases only blue cartridge has ink on it.
Posted on Nov 12, 2008
My MP600 will not print documents. It will print a scanned document i.e. scan the doc and print from the image. It will print a webpage. It will print a copy it makes but it is blue instead of black....
If colours are faded I would recommend running several cleaning/deep cleaning cycles to try and pull through the colours. It is difficult to say without seeing the print quality, but it sounds like an issue with a partially blocked printhead within the printer.
The printing in blue would suggest to me that one of the blacks in your printer is blocked. Were all 5 colours present on the nozzle check?
Jul 31, 2013 | Canon PIXMA MP600 all-In-One InkJet...
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Canon pixma ip3000 print problem
tthanks about that but i dont know how to deel with that
Dec 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP CP1700 - no cyan or blue printing
Try taking a look at your printheads. Have they been installed for some time. You may need to change them. Start with the Cyan first.
Inkworks
866-381-0541
Oct 24, 2008 | HP cp1700 Color Inkjet Printer
Xerox 6250dp
I had this problem when I used a generic toner. I installed a xerox cyan toner, then printed many sheets of a large blue rectangle. After about 15 pages the blue started to spread into the shape, after 30 pages the blue was back. Printing a lot of blue was necessary to get the new toner thru the system.
May 29, 2008 | Xerox Phaser 6250 Laser Printer
Printer cartridge
Please See Ink level from Software ; Else change the cartridges with New One ; If It prints Only Blue. Refer Back to me.
Mar 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
