Zenith XBR617 DVD Sometimes doesn't record full time scheduled
I have a permanently timed DVD recording session scheduled for 60 minutes for a day of the week. Lately, rather than recording for the full 60 minutes, it will stop recording before the 60 minutes are up. Tonight it stopped 12 minutes into recording. It's not always the same length of time. I have replaced the DVD-RW with a new one yet the problem still persists.
Anyone have an idea of what's causing this annoying problem?
  • x002009 Nov 12, 2008
    Thanks for your response DanMart
    Regarding the clock: the clock has the correct time (although it does run a little fast ... need to reset it once or twice a month)
    Regarding to power: Doubt this is it. We haven't had a power interrution is years, if not decades. We were watching the TV on a different channel, and saw no "blips" in the broadcast. Would have expected a quick "jumble" of the image if there were a power issue.
    Sergeant:
  • 291 Answers
Sounds like your clock is wackie. SEE if there is a back up [computer type button] battery in a small draw just by the clock or see your manual for directions on where it is. Replace the battery.Do you have interupted electircity in your [brown outs] area ? That shuts down the recording timer and resets it. Your clock is the 1st thing I would check, 2nd is the electricity.
Posted on Nov 12, 2008
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
Is there a way to change vhs tapes to dvd?
Yes there is! It will require some special equipment and software, but it's not too difficult. Here's an online guide that will show you everything you need: http://www.vhstodvd.com/ Hope it helps!
Aug 28, 2011 | Zenith XBR617 DVD Recorder/VCR
Zenith XBR617 shows No Disc after disc is pud in. Am using Memorex DVD-R. Used to work - does not any longer.
This appears to be a bad laser, or dirty laser.
Purchase a cleaning kit from your local electronics store (5 - 10 dollars) and run it through the DVD player. If this does not resolve it you may need to contact an electronics repairman, or use your manufacturer warranty. Though these are mostly throw away technology and maybe more cost effective to replace with an updated model.
Feb 28, 2011 | Zenith XBR617 DVD Recorder/VCR
I have a Zenith XBR617 DVD VHS player/recorder that does not recognize DVDs when they are inserted. I have contacted the service center before and they were no help. Someone has suggested that I clean...
Hi Henrybf.
If you have an owners manual try looking in there to help you with the problem that you are having. If you don't have an owners manual you can download one from the Zenith website in PDF/Adobe reader form. You may even be able to purchase replacement parts from them. Hope this helps.
May 23, 2017 | Zenith XBR617 DVD Recorder/VCR
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Hi, Have just purchased Samsung DVD HDD recorder (DVD-SH855). Everything works great except the timer recording. When i schedule a recording, the system wont start recording. The recording light flashes...
I had the same issue. It turns out that the recorder has to be switched off otherwise it won't record. The unit will power itself on at the scheduled time and record your program. It doesn't make any sense to me why this would be a requirement but it solved the problem for me.
Jul 06, 2008 | Televison & Video
Searching for manual
guide uploaded, fixya will review and post in 24 hrs.
Dec 18, 2007 | Zenith XBR617 DVD Recorder/VCR
ZENITH XBR617
You can order a new drive from Zenith parts 1-877-993-6484 - the unit information is ...
6721rd021c $100.94 - 2 day shipping
When I get home I'm going to crack the shell on the DVD drive inside the combo set and see if it;s a simple 'off the shelf' RICOH/PANASONIC/MATSUSHITA DVD-R drive tho. If it is, the replacement part (but not the spec. part from Zenith) from Fryes might be faster and cheaper? Not sure yet.
Nothing records when I do a scheduled recording
Doesn't record properly, ie: looks like one channel is down when recorded, pre-recorded tapes are ok
Check Q008 for dry joints
Nov 24, 2007 | Panasonic DMR-EZ37VS
Numeric cod
Nov 06, 2007 | Zenith XBR617 DVD Recorder/VCR
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
