Question about Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061)
How i get a wireless network.my distance from the wireless is 100meter.what is the solution for this?
  • Belkin Master
  • 6,487 Answers
Since your computer is having some problem in getting the signal from your wireless router , you can get a wireless range expander so the signal can reach your computer that is far from the wireless router, you can check this out from Linksys WRE54G...
Posted on Nov 12, 2008
Dynex DX-E102 PCI co/100Mb Network Adaptor provides really slow connection to my Dell Dimension 8200 PC. How can I speed it up?
speed is a function of line of sight distance so measure distance from wireless router for pc and then open that utililty on pc and see what relative speed is happening
if the signal is less than 3 bars, that is like a wireless tach
need at least 3 to 5 bars to get speed
also, your pc has a network adapter card no doubt might be that it's running a full tilt and needs an upgrade
let me know what you find
May 31, 2012 | Dynex Computers & Internet
How do I connect my printer so that I can print wirelessly via my wifi network?
if the printer is within distance of your wireless router, run a network cable between the two. if the computer can access the wireless router it should be able to access the printer connected to the router.
Aug 26, 2011 | Lexmark X2670 All-In-One Printer
My toshiba laptop with a realtek rtl8187b wireless 802.11b/g usb 2.0 network adapter, is connected to a wifi network with internet, but periodically the connection is lost (connected and automatically...
This is not a problem. Wireless connections sometimes tend to be inconsistent. Try closing the distance between your laptop and the wireless network adapter.
Mar 17, 2011 | Toshiba Realtek RTL8187B Wireless...
How far away can my wireless G router be from my xbox adapter
It is about 50-75 feet depending on how many obstructions are in the way (Walls, Ceilings, etc)
Oct 23, 2009 | Microsoft Wireless Network Adapter Xbox...
I use this computer for home use only. Would like information on wireless routers and if I need any other gadgets for wireless set up.
you mean you want to connect internet or local network through wireless connection? you need an wireless access point(WAP) also known as Wireless router, but be sure the wireless router you want to buy is compatible with your wireless network built in to your laptop. no other gadgets to need if your laptop have already wireless network and if you want using within a range distance only otherwise you buy wifi antena.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
No wireless internet on my brand new acer aspire one mini
- Check the toggle switch of your computer make sure that it is Enable
- Check if you have 3rd party software that is installed to the computer, that can use to connect wirelessly.
- Check the distance between your router and computer (100 meters is the maximum distance)
Feb 18, 2009 | Macsense AeroPad Mini 802.11g/b (WUA800)...
Wireless Network Disconnecting
u have to reset your wifi router.
reset switch is in back of router and configure asgain.if u not need static ip then comfigure as dhcp
Jan 06, 2009 | Linksys WRT160N Wireless Router
Connet my home pc
obviously, you cannot use a cable to link up from your office network.
1 know your provider and the kind of WAN service offered
2.Get a router that is compatible with your office network and configure your router with similar priorities with that of your officce network(a wireless radio might be require)
or if you are not vast networking,invite a network administrator to do it for u
Apr 14, 2008 | Computers & Internet
Intel 2915AB Connection problem
Intermittent disconnection issues on a radio/wireless network will generally be caused by interferance (speakers, power board fully loaded, High wattage Lamp (flourescent bulbs usually) all parked too close to the wireless router, access point or network card. or possibly due to interuption of the active signal possibly because the distance of the router and network card/access point is just on the edge of the best signal limit and disruption occurs when someone or something gets up and moves itself inbetween the two service points)I resolved my disconnection issues by purchasing a wireless Kite for the access point and router, which will intensify the radio signal and bring the access points within closer range of each other, friends of mine have resolved intermittent signal issues by making a thin tube of rolled tinfoil about 30cm long slipped over each aerial affected by the intermittent signal disconnection. Also verify the "line of sight and non line of sight" signal distance limits for your radio equipment as the signal distance will decrease depending on the age of your wireless equipment, most equipment is in the 30Ft non line of sight- 100Ft line of sight arena out of the box but you can expect to half this figure after 3 - 5 years of continued use. Basically three options Interferance, Interupption or age only distance testing will verify this accurately IE: bring the router and access point withing 1Ft of each other and start walking away still holding the access point, whilst a user monitors the radio network condition.
Aug 04, 2006 | Intel 2915ABG 802.11a, 802.11g/b Wireless...
Maximum range
Since wireless networking uses radio frequencies to communicate between your computers and networks, the maximum distance that 802.11b can operate depends on environmental factors that will affect your network: 802.11b Typical Outdoor Coverage Area 802.11b Typical Indoor Coverage Area 590' 11Mbps 50' 11Mbps 984' 5.5Mbps 125' 5.5Mbps 1476' 2Mbps 150' 2Mbps 1800' 1Mbps 200' 1Mbps
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Belkin 802.11g Wireless Desktop Network Card [ F5D7000 Wireless ] (109061) Logo
53 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
