Question about Whirlpool Dryers
The dryer will not start - the sensing lite comes on, and thats it. the motor doesnt even attempt to turn. the door open lite (in the drum) works with the door switch
  • 60 Answers
Sounds like the drum belt is broken there is a cut off switch to prevent the dryer from running/overheating if the belt may break
Posted on Nov 12, 2008
  • mike Dec 19, 2012
    belt ok , where is the termaol cut off fuse located at.
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Drum doesnt turn dryer makes buzzing noise
Just fixed one with same problem for customer. Sorry to say but most likely faulty motor. One test you might perform, and this isn't full proof but, is to bypass door switch and attempt to turn drum by hand whilst engaging starter switch. If dryer starts it is most probably motor. Also If this usually occur after heavy usage, or has in the past, it's almost surely faulty motor.
Aug 20, 2013 | Dryers
Dryer makes a buzzing noise when I turn it on but it doesn't come on, just buzzes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
What is the model number?
Nov 06, 2012 | Dryers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
I have a 5 yr old GE Harmony Dryer and it sometimes does not turn the drum. I'd say about 2/3's of the time it operates totally normally, but the other times the drum doesn't turn and you have to open the...
Unfortunately your motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are GE certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on doing it yourself, if you'd like.
The switch your talking about is a centrifugal switch inside the motor. Once the motor turns to a specific RPM, it makes and keeps the motor going until the timer turns it off or the door is opened. But it is the motor itself which starts the spinning. But the motor is not doing it's job so the C switch doesn't come into play.
Best, G
Aug 02, 2010 | GE Profile Harmony DPGT750EC Electric...
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Whirlpool dryer will not start
open top panel should flip up two screws at lent trap screen if on top of unit when top panel is up push start button then push drum while you hear that buzzing noise if drum starts it needs a new motor
Feb 21, 2009 | Kenmore 63942 Dryer
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Open Questions:
Dryers Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
