Question about Ricoh Aficio CL2000 Laser Printer
Error Message: Replace Black PCU
I have an error message that reads: Replace Black PCU. What is a Black PCU, where is is, and how do I go about replacing? The printer originally quit working, when this message appeared, but once I turned the printer off and restarted it is now printing, but the message is still there.
  • Anonymous Mar 20, 2014
    my printer just starting showing function error SC899 with the instructions to turn off and restart. Well I have done that and the error message keeps appearing, any suggestion of what it might be and what I can do to fixes the problem?
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Posted on Nov 16, 2006
Call Rioch
Posted on Apr 01, 2008
Where can i get a transfer belt for Ricoh CL2000? Thanks for your help
Posted on Jul 10, 2008
SC 491 error message
sc 491 is error signal is detected for 0.2 seconds when charging the drum or development.
• High voltage leak
• Broken harness
• Defective drum unit or development unit
• Defective high voltage supply unit
Oct 19, 2016 | Ricoh Office Equipment & Supplies
ERROR SC682-223 ? Also, Error for CPU cyan at starting.
Memory chip at TD sensor: Communication error
Retry of memory chip communication fails three times after the
machine has detected the memory chip communication error.
?? Damaged memory chip data
?? Disconnected inter face
?? No memory chip on the development unit
?? Noise
Replace the PCU.
Jan 06, 2016 | Ricoh Aficio SP C820DN Laser Printer
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Error message: replace pcu
I believe its asking you to change the photo conductor unit. From what I can tell there are 2. Theres a black photo conductor and a color photo conductor. If its not telling you which one you should be able to print a supplies status page and you can see which one needs to be replaced. I'm not totally familiar with the machine but the PCU's should be located in the cartridge area. I just checked out our supply catalog and you should be able to order them from any office supply store or Ricoh dealer. Just a heads up..from what I'm looking at the black pcu is pretty reasonable, but the color one is $300 plus! For your sake I hope its the black one that needs replacement! You should be able to verify the error message in your user manual and more than likely find the part number for ordering.
Jul 08, 2009 | Ricoh Aficio CL3500N Laser Printer
Error message "replace black pcu"
Photo Conductor Unit. Instructions come with the replacement. Installs from left side. Read instructions carefully.
Feb 19, 2009 | Ricoh CL4000DN Laser Printer
Error message
the pcu stands for photo conductor unit it is more commonly known as the drum.
Jan 13, 2009 | Ricoh Aficio AP3800C Laser Printer
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Oct 15, 2007 | Ricoh CL3000E Laser Printer
Ricoh Aficio CL2000 Laser Printer Logo
7,821 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
