Question about Dell Dimension 2400 PC Desktop
HOW DO I REMOVE COVER OF 2400 TOWER,INSTALLING 80G HARD DRIVE
  • Dell Master
  • 998 Answers
Here’s a link to the service manual for 2400: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
My dvd drive wont open
Use a needle or pin and insert into a small hole on the front to engage the emergency release, then try cleaning the tray thoroughly
Aug 17, 2012 | HP RT917UTABA - HP Promo dx2300 micro...
Windows has password which i have not put my self and i do not want to format machine.
go to control panel>user account, then remove password, if it didnt work got safe mode then do that step
Jan 20, 2011 | HP RT917UTABA - HP Promo dx2300 micro...
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
2000 pc tower , how to remove hard drive
1. Remove a side panel from the computer tower. http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/rmvcvr.htm
2. Hard drive removal: http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/drives.htm Look down to the Hard Drive section of this link and you should find some detailed instructions.
You will probably just need a phillips screwdriver to get the job done. Maybe a pair of small pliers depending on how tight the cables are connected. The amount of finesse you use is dependent upon if you want to reuse the drive or computer.
Dec 22, 2009 | Dell Dimension 2400 PC Desktop
I need help installing a cd drive in an Antec Sonata III 500 computer case. How do I do it?
Unplug the power from the computer. Open the case cover. Carefully remove the placeholder on the front of the case where you wish to install the CD drive. Make sure you have the proper ribbon cable for the type of drive you are installing and that you know where to plug it into the motherboard (consult your motherboard manual).
Use the screws provided to secure the drive to the chassis rails (make face of drive flush with front of case). Attach an available power supply connector to the new CD drive. Close the cover.
Dec 04, 2009 | Antec Sonata III 500 - mini tower - ATX ...
How to remove cover on a dell dimension 2400
Slide the plastic "L" in the back down (facing the back of tower it will be mid right) while holding the "L" down slide the side cover towards the back (facing the back of tower it will be the right side cover) It may take a little persuading!
Jul 02, 2008 | Computers & Internet
Compaq d540s hard disk upgrade
Jackwan -
Sounds like the boot record of the drive may be corrupt. When you runs the XP installation, you'll be given an option to start the Recovery Console. Go ahead and open that, should bring up a command prompt. At the prompt, type "fix mbr" (With the quotes removed). Select Yes or Continue when asked, and go through the repair process, then reboot the system and try installing Windows again.
*Note*
You might want to check first, make sure the jumpers on the hard drive are set to Master, or Cable Select, and make sure the drive is connected as Drive 0 on the Primary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | HP Compaq d530S PC Desktop
Dell Dimension 2400 PC Desktop Logo
140 people viewed this question
Alun Cox
