Question about Minolta EP1083 CS/PRO Copier
I always show machine is not ready with turnover at the cylinderIt is noted at the operation and a consumption of ink
  • Minolta Expert
  • 1,326 Answers
Not really sure what you are asking?????? It use toner not ink..... Need a little more info.....
Posted on Nov 12, 2008
My 1993 camry is now high on fuel consumption after engine haul. what could be the cause?
Check cylinder compression.
Any applicable trouble codes?
What about a tune-up?
With any problems after engine over-haul, I always check cylinder compression.
Apr 15, 2016 | Cars & Trucks
Using ink cartridges faster than normal.
The picture shows the cleaning resovier. Each time the cartridge pass buy the print head is wiped and residue is deposited there. Looks messy and it is. As for the cartridge usage, they may be an economy selection in your software that may reduce ink consumption. Of course if you are printing in color versus black and white the consumption increases substantially.
Jan 30, 2015 | HP Photosmart Premium C309A All-In-One...
The temperature guage in my 1996 Ford Taurus always reads over 3/4 of the way up. The car doesn't overheat. It just shows it as always running hot. I have flushed the system and put in fresh anti-freeze. I...
Change the sensor. Check the electric cooling fans and Relays. Some fans have 2 speeds and may not kick into high speed.
The radiator operates more or less closely to the block temperature. A Laser thermometer would tell you what the operating temperature is.
Aug 11, 2013 | 1996 Ford Taurus
My hp 1040 fax will not print after replacing ink? yes i removed the tape
Replace right away your fax machine and your telecom line subscription! Time to switch to a cloud-based fax service: no ink, no paper, no cartridge. The internet fax service is always on, always ready - 24 hours a day, 365 days a year.
Jul 25, 2013 | HP New 1040 Inkjet Fax Machine W built in...
Dont know how to replace printercartridges in mx700
Install the print head or ink tanks properly following the procedure If reseating or reinstalling to clear an error, the ink tanks and print head must first be removed.1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.Note: When the top cover is opened more than ten minutes, the print head moves to the right side.If this occurs, close the top cover, and open it again.2. Open the paper output tray.Note: When installing the print head, roceed to step 3.When installing the ink tanks, proceed to step 6.3. Raise the print head lock lever.4. Pull out the print head from its package, then remove the orange protective cap from it.Note: Do not touch the print head nozzles <1> , electrical contacts <2>, or ink supply ports <3>.Doing so may cause printing problems 5. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.6. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.7. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.Note: - Do not touch the ink tank contact <1>. Doing so may occur printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
8. Insert ink tanks into the print head.1) Insert the ink tank into the Print Head.(2) Press on the 'PUSH' mark on the ink tank until the ink tank snaps firmly into place.(3) Ensure that the ink tank lamp lights red.Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes. On: The printer is ready to print. Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank. Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.- Off: An error has occurred and the printer is not ready to print.10. Close the top cover.Note: When starting printing next time, the print head cleaning launches automatically.During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
Sep 20, 2011 | Office Equipment & Supplies
During its warming up cycle, my Xerox Phaser 8560 stop before it can sent a text page and show ''printer error 09, 038, 46:1172'' on its display. Printer do not become operational at this...
Here's what the service manual has to say:
9,035.43 through 9,038 (8500/8550/8560 only): Ink count sensor flags are
stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41,
where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black.
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out
Sensor located at the forward end of each ink channel of the Ink Loader. The
sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This
can lead to false Ink Out messages as well as Ink Stick count faults. Using
8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick
count faults.
Jul 18, 2011 | Office Equipment & Supplies
I have a Canon MP510 printer and have changed the print cartridges many times for refills but am now always getting error 6502. I've tried turning it on and off, unplugging it, holding down power button...
hi,
you mentioned that you turn off and on these is on of the solution of your problem
but in your case it doesn't work
error 6502 arise when ink tanks not snapped properly
follow the steps below
  1. Confirm that the printer is powered on and pull open the paper output tray .
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place.
note:
Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
5.Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
1 -tank installed properly
2-not installed properly
6. check the status of each ink tank according to the way its lamp flashes.
  • - On: The printer is ready to print.
  • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • - Off: An error has occurred and the printer is not ready to print.
  1. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
  2. regards,
  3. cseian
Dec 16, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Impossible to insert the cartridge in a printer always shows that it is not a good loaded
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support <1> is fixed into position, release your hands.
    *MP470 shown
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Nov 30, 2010 | Canon PIXMA® MP210 Printer
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
4. Put back the inner cover and close the top cover.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
16 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
