Question about Sharp AR-157E Copier
Error H4 the machine stays with the H 4 changing and does not do anything else
The Machine is either too hot or to cold. It maybe a thermostat or it could be the fuser. Ether problem will require a technician to examine the copier.
Posted on Aug 21, 2007
Error code H/4
enter service code # interurpt c interupt , machine goes off then enter 14 then press print button. this will cancel error code H4.
Mar 04, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp copier error H4
fixing assembly related. check:-
1. Thermistor.
2. fuser lamp.
3. If fixing assembly is receiving PD from power supply if not change power supply.
4. reset the machine using SIM 14 (pressing in quick sucession 'clear' 'Auto' 'clear' then 14 and copy button.
Jul 13, 2011 | Sharp AR-5316 Advanced Digital Imager...
Our copier is an AR-208D & it has a error code of H4-00 displayed. Can we fix it?
In most cases the flashing H4 or H then 4 code on these machines is caused by voltage fluctuations or surges. Normally there is nothing wrong with the machine and the code is easily reset. Here is the procedure:
Press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "#" then the " * " (star) key then the "Clear" key then the " * " key again.
So in other words #, star, C, Star
If done correctly the display should go blank.
Then key in 14 as if you were going to make 14 copies.
Now press the "print" button
The machine should automatically shut down and restart with the H4 code being gone.
If the H4 code comes back after reset then in this case you have a fusing unit problem and will need to have the unit serviced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Sharp AR208D Copier
Toner was changed, m/c powered,and instead to ready it was showing ERROR 021
Function 7 press monitor slowly 4 times * 6 scroll down to SHIPMENT SET set 2 wait for the fax machine to reboot
Jun 03, 2009 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
Error code H4-00 and machine is "locked-up" in scan mode
H4 is a fuser error. It needs to be replaced by a tech. Sometimes they can reset this error in service program.
Apr 24, 2009 | Toshiba E-Studio 3511 Color Copier
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
Eror Code (H4-00) on a Sharp AR-162
H4-00 indicates a heating/temperature problem in the fuser. The fuser never reached its desired temp to come to ready. Could be a bad thermostat or thermistor. Check fuser for any debris or excessive gunk build-up and clean what you can. The error can be cleared with SIM 14 in service mode.
Mar 19, 2009 | Sharp AR-M162E Black and White Copier
Code: H4-00, H4-0Q
H4-0 The fusing unit doesn't heat up.
You have to reset fuser errors with simulation 14.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Jan 25, 2009 | Sharp AR-M350N Copier
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-157E Copier Logo
130 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
polytek
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
