Question about Compaq Armada E500 Notebook
Does nothing compaq screen shows, pressing F2 or DEL does nothing - unit beeps then screen goes black with white underline flashing in upper left corner.
    President:
  • 2,961 Answers
This indicates, it has lost the initial boot settings in the bios for a p.o.s.t. and if inseting your xp disc into cdrom drive at boot up doesn't do anything either, possible cmos battey flat and requires checking and replacing. The motherboard may also have a fault as it's getting on a bit.
Posted on Nov 10, 2006
  • andrew pester
    andrew pester Nov 10, 2006
    Sorry also meant to say that you may also need to get the hard drive checked out, as it may be damaged and as is to why it can't find the masterboot record.
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Black screen flashing dash top left corner. ....wont reboot after system restore
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Apr 03, 2012 | Computers & Internet
How can i enter BIOS set up pf Compaq Armada M700
Usually the delete key or F2 will do the trick
Mar 09, 2011 | HP Compaq Armada M700 Notebook
My laptop Preasario cq61 has the black screen problem, when it starts it shows the first screen fine ( the one where you can hit ESC to enter the bios) after that it goes black and in the top left corner...
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
Apr 11, 2010 | Compaq Presario Notebook
My computer goes to black screen with flashing cursor in upper left corner. does this mean i need to reformat my harddrive and reinstall windows? i didn't install anything new i just rebooted the computer...
Wen yu power up press F2 or F1 or 'del' key to enter in bios check your harddisk is detected in bios.
Open cpu cover and refix RAM memory and reconect power cable and sata or ide cable to harddisk again.
then ceck.
Jul 27, 2009 | Computers & Internet
-lost bios will not open on startup pressing DEL -screen is black with small white bar flashing in left top corner -presing F1 or F2 brings up invalid system disk, replace disc & press any key, or...
U do a flasing of ur BIOS, there will a jumper on the mother board, U can find it refering the manual of ur mother board, jst change the jumper to flash the BIOS, then try booting...
Mar 21, 2008 | Computers & Internet
Compaq Armada E500 Notebook Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
