Question about HP LaserJet 2840 Printer
Hp 2840 laser printer
All of the copies come out with a faded grey line left of center on copies
  • 345 Answers
Are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there.
Posted on Nov 12, 2008
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I have an HP 2840 color laser jet that keeps presenting a Scanner Error Code 6. Might anyone know if and how I can repair this on my own? Thanks a ton! Mike
replace optical scanner assembly..(a unit located in flat bed scanner with florocent lamp moving left to right while scanninf & copying)
Sep 17, 2011 | HP LaserJet 2840 All-In-One Printer
When i use the sheet feed on my hp laser jet 2840 to photocopy the printed page has a black line down it what can i do to get rid of this?
Clean the adf scanner glass. This is the thinner strip of glass that is just to the left of the large original glass. Just lift up the top feeder and look to the left side of the glass. Clean this strip of glass with a soft cloth and some glass cleaner. Sometimes whatever is stuck to the glass is hard to get off so keep at it till it goes away. Another tip is if the line is in the middle of the copy then the "spot" to clean is going to be in the center of this strip from front to back. If the line is to the left side of your copy then the spot is going to be towards the front side.
Good Luck and Than You for using Fixya
WheatlandServices
Nov 14, 2010 | HP LaserJet 2840 All-In-One Printer
HP 2840 will not print on 3 inches of left side of page
Take the toner cartridge out, shake it back and forth, and turn it around in a circle a few time. Put it back in the priter, and print. Order a new toner cartridge.
If this is an inkjet printer, ignore this response.
Apr 21, 2010 | HP LaserJet 2840 All-In-One Printer
Top to Bottom gray line on left side of Copied Page
hello
does the grey line appear if you scan true the "upper" scanner.(set paper on top of printer and sscan it that way)? you should also clean the smal slim glass that is at the side of the big scanner glass.
also try to remove all cartridges and tilt them side to side several times. then put them back and test your printer.
Jul 02, 2009 | HP LaserJet 2840 Printer
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
Feb 27, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
93 people viewed this question
Seeker5211
Seeker5211
