Question about Bialetti Moka Express 3-Cup Espresso Machine
How do you use the French press pot-e.g.INOX or Bialetti?
I am having problems with how to use the INOX 18-10 pot I inherited. I know how to use simple espresso pots with no problems, but this I am having problems with. Where do I put the little presser?
Thanks. Please e-mail me any instructions.
Thank you- pattycf@msn.com
  • 52 Answers
SOURCE: Where can I buy a replacement espresso pot
Update: Salton replacement parts and owners manuals can be ordered at 800-233-9054 or by emailing consumer_relations@toastmaster.com
Posted on Jan 31, 2008
Al42
  • 72 Answers
SOURCE: Salton espresso maker - glass pot
Contact Salton and ask them who near you carries replacements.
http://www.saltoninc.com/contact/index.html
Posted on Aug 19, 2008
  • 7 Answers
SOURCE: Espresso irregularly spurts out the center post
It IS the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Funnel had NOTHING to do with my problem. Also cook on medium to low heat. High flame seems to make the problem worse.
Posted on Jul 17, 2009
  • 7 Answers
SOURCE: Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
nethload
  • 22 Answers
could it be that the gasket is oversized and it covers the small holes ?
Posted on Oct 28, 2009
Only little coffee is coming up
Although the gasket looked fine, once replaced the coffee pot functioned correctly.
Mar 30, 2014 | Bialetti Cooking.com Stovetop Espresso...
My Moka Easy Bialetti electric espresso maker switches off before all the water has been percolated through into the upper pot. I have recently replaced the rubber seal etc. at the base of the pot.
I emailed support at Bialetti and here is what I got:
Check the coffee funnel for any dents around the edge of the funnel. Normally if this brewing problem happens after changing a gasket the problem is a dent or the funnel is out of round and the new gasket isn't formed to it like the old gasket was. Don't bang the funnel to get grounds out or it may dent or get out of round. Try pulling the funnel over to one side in the water chamber and if you see a space on one side pull it tight with the other finger to bend back into shape if possible or replace the part.
Take the gasket and filter plate out from under the upper unit and hold the filter plate up to the light to check for any clogs right in the center where the coffee brews up. You should be able to see through all the holes in the filter, brush clean if needed
Jan 13, 2011 | Bialetti Moka Easy 6-Cup Espresso Machine
Corrosion on my Bialetti Moka stove-top
You can buy a new one or Google "Bialetti parts".
Jul 27, 2010 | Bialetti Moka Express 3-Cup Espresso...
Someone gave me a stovetop espresso maker but there were no directions. How do I use it?
If this is a Bialetti, twist off the bottom part of the pot. You will find a sieve that you can take out. Inside you should see a marker on one of the sides. Pour fresh cold water up to this line. Put espresso in the sieve and pack it a little. Put everything back and put the pot on the stove. The water will heat up and be pressed through the coffee and up on the upper part of the pot. After a while all the water is through and you may serve a nice cup of espresso. Enjoy!
Jul 09, 2009 | Coffee Makers & Espresso Machines
Coffee has started becoming weak
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 21, 2009 | Bialetti Mukka Express
Mar 08, 2009 | Bialetti Mukka Express
Feb 09, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Good evening! I have received the  Kontessa  Vev Vigano  12 cup from my family  but I don't have an  instruction book with it..  is there a  place where I can download  some simple instructions as to how...
You could use any Bialetti or Vev Vigano instructions created for aluminum pots. I have a 6 cup Vev Vigano Kontessa Inox, but the instructions that came with it were standard. Remember to use correct measurement of water and coffee. Coffee grind should be espresso. I don't know about 12 cup, but assuming that it's double of the 6 cup size, I use 9 oz of water and 6 tablespoons of espresso grind. You could go to www.vev-vigano.com. Their customer service is pretty efficient. Even if you didn't buy your pot from them, they'll reply usually within 24 hours. Good luck.
Jan 02, 2009 | Vev Vigano Kontessa Oro 12-Cup Espresso...
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti Moka Express 3-Cup Espresso Machine Logo
104 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Pennywhistler
Pennywhistler
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
