Question about Tomtom GO 720 GPS
Problem with map
Used gps once, went on line to check for updates. after that all i get is a message that says you cannot use this map on this device:australia-14. when i push the ok button it asks for a map the only option is australia. when i push that it goes back to the first screen and will do no more
  • 7 more comments
  • alraine Nov 12, 2008
    had a suggestion from ginko but device does not have memory card or cd
    yes pressed reset and it came back the same
    i can not find a memory card. ther is sticker on bottom sayind no sd required
    when i press the reset button should it come back on with the same warning about the map because this is what is happeninng
    thanks bestdarngood have submittted problem but may be two days. shall get in touch when i hear from them
    marked don't know what you mean by reflash
    vegkitten20 not sure how to do you don't get much useful information on the disc that came with it. i am an older person so not very gadget literate but am trying to learn
    flapveri. you need special tools to open unit and don't want to void warranty
    no that has not worked either. it tells me that it is alredy on and the only option it gives is to buy one
    Master:
    Sergeant:
  • 449 Answers
Hi!!
may be you download the wrong version or your
unit
try to reinstalled the sofware!!
or reformat your memory card
or buy new one
Posted on Nov 12, 2008
    Genius:
  • 1,011 Answers
Sir,
click this link for "How to Update"..........
http://forums.techarena.in/tips-tweaks/956549.htm
thanks
good luck
  • Asfiya Ahamed
    Asfiya Ahamed Nov 12, 2008
    Sir,
    If you are having one of the problems
    described below, it could be that there are too many files in the flash
    memory on your device:
    • You are unable to activate the map on your TomTom device even though you have a valid product code.
    • You have to enter the passkey every time you connect your TomTom device with your mobile phone.
    • Your settings are not saved when you turn your TomTom device on and off.
    To fix these problems, follow the instructions below to download and run the TomTom Clear Flash tool.
    Click this link for more information....
    http://www.tomtom.com/support/category.p...
    Good Luck
    Thanks
    President:
  • 2,712 Answers
You've most likely downloaded the wrong version for your unit. Go back to the website and select your device model and try a reinstall.
  • 4,472 Answers
For helpful phone support, call 866-486-6866 Try this first as they will be able to give you the best support for your exact model. If you still need assistance after contacting support at that number I will assist you further. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • Lee A.
    Lee A. Nov 12, 2008
    Because the unit is under warranty you will want to contact support using the number I gave you first. If you still have questions once you have done that I will be more then happy to assist you further. Once again please take a moment to accept and rate my solution accordingly.
    Thanks again,
    Lee
    Sergeant:
    Champion:
  • 393 Answers
Remove batteries for few minutes then reboot it.
  • 685 Answers
Have you tried to uninstall and reinstall it try that and if that don't work then we can try something else
  • 6,487 Answers
You may need to reflash the software update for this GPS so it will be working fine again....
  • Mark Gil
    Mark Gil Nov 12, 2008
    You need to reload the software of this GPS unit and if that failed don't try to open the unit because that will void the warranty better to have it replace....
  • 3,037 Answers
Try this from the TomTom website and let me know how it works and we can work from there on your problem if it doesn't work
http://www.tomtom.com/support/category.php?ID=1&Language=1&query=clear+flash&FID=6178
  • Benjamin Patri
    Benjamin Patri Nov 12, 2008
    Did you click on the link I provided and try to go through the troubleshooting steps on the link?
    Please let me know how the link works out as it is not just a contact page
    Sergeant:
    Champion:
  • 331 Answers
The Updated map might not have been compatible   with your GPS
either  you  will  have to revert back  to the old  map.
 Or  once again update to a map which will be recognized.
otherwise try to reset your your GPS to the default Factory settings
If you had a CD with the device it would contan the software to Reinstall the GPS  you could try doing that.
  • Varun Kumar
    Varun Kumar Nov 12, 2008
    I think you will have to  update it again  you might have downloaded a  wrong version of the map
    and there might ot be  any probem with your GPS device .
    Scholar:
  • 112 Answers
Reset the GPS and re-install the software. That should fix it.
  • Steve DiPolito
    Steve DiPolito Nov 12, 2008
    After reading all the things done and looking into the things that you can do, all that is left is contacting the manufacturer.
  • 94 Answers
The Maps on your Memory Card might be corrupted or not being recognize by the GPS device. Try to turn off the device. Remove the memory card and wait for a couple seconds then insert it again. Turn on your GPS and check if it will read the other Maps.
    Genius:
  • 1,550 Answers
Have you tried reset option on your gps.
  • SAM ANDERSON Nov 12, 2008
    You need to contact tomtom phone number -1300 135 604.
    Most of tomtom 720 gps has problem in downloading australia map .
  • 19,396 Answers
Check that the memory card or the cd with maps is installed properly, remove card and put it back in place.
Navigation map do not show up, next turn etc. Also show message "no map info".
My problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformated the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Mar 20, 2016 | Garmin nuvi 50 Travel Assistant
Can not put an address in garmin nuvi
Try running an update with Garmin Express, let it sit for 30 Min after it says it is done, then check again
otherwise you may have jsut installed a smaller region ,... again Garmin express could help.
Aug 04, 2014 | Garmin nuvi GPS
Corupted map after update? How to correct?
Perform the update again. I think was an error on the first update.
Try the below procedure:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Jan 06, 2012 | Garmin Nuvi 760 Car GPS Receiver
Just got a new garmin 1300lm and there are no maps in it. I tried to download maps from their website and I keep getting the message "your device does not have enough space for this region". A...
I would return it, you can only update a map that is installed. Once you get a unit that works, back up the entire unit by copying its contents to your computer hard drive before updating the unit just as a precaution.
Thanks for using FixYa
Aug 17, 2011 | GPS
I need to downlaod the 3220 maetro gps
Maps are done at least once a year. You do not have to update the maps but you have firmware updates you must at some point update. there is a disk that comes with the unit when new. Install the disk - this installs the drivers or language your pc needs to talk with your Maestro. Once your driver program is installed plug the USB cord in that came with the unit. Once everything is hooked up you need to go to the Magellan website - download the updates and install them Then and only then will the message stop. 1d80823.gif
May 08, 2010 | Magellan Maestro 3220 Car GPS Receiver
Xls 330s tom tom no map
Connect the GPS to the computer. Forget the Tom Tom home for a little while. Use the windows explorer or file manager. Check whether the TomTom is shown as a drive. If yes, Right click on it. Then click properties. Check how much is the used space and how much is the free space. If you see that there is only about 50MB free space, that could be the reason. Tomtom update do not seem to overwrite the map file. Now check the properties of the new map file. It may be approximately around 1.3 GB to 1.5 GB. Since I do not have a Europe map I do not have the correct size. If the new map size is anything bigger than the available space on your GPS drive, then the update will not complete and crash. Solution. Copy the existing map (North American map has a name something like USA_Canada_and_Mexico_P) folder to your computer. Once you have a secure copy, delete this map folder from your GPS drive. You will now see that you have approximately 1.7GB of free space. copy the map folder from your CD to your GPS drive. Once copying is complete, safely remove the GPS from USB port. Restart and try it out on a known route to check efficiency.
Apr 15, 2010 | Tomtom XL 330 Car GPS Receiver
Free map update from garmin messed up my nuvi
check if the maps are tickked , go to settings and maps and check which are ticked, if not wot does not work right?
Dec 27, 2009 | Garmin nuvi 255W GPS Receiver
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Oct 20, 2007 | Garmin StreetPilot 2620 GPS Receiver
Tomtom GO 720 GPS Logo
23 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
