Question about Honeywell Programmable Thermostat Heater
New honeywell thermostat on new gas furnace not working
I installed a Honeywell RTH230B digital thermostat on a new gas furnace. With the mode switch on "heat" and the fan switch on "auto", bumping the temperature up does not cause the furnace to run. I moved the fan switch to "on" and the fan started, but not the burner. I then removed the thermostat and jumped the red and white wires together and the furnace started right up. I thought - bad thermostat- and bought another one. It did the same thing. I checked the instructions and they mention a 3 minute delay for cooling, but not for heating. Any help would be appreciated.
Dave
  • dave756 Nov 12, 2008
    I did manage to solve this problem. The thermostat uses 2 AA batteries that reside in a compartment at the top of the thermostat. That compartment bulges out toward the wall and I think the wires coming in from the furnace were getting trapped between that and the wall. I think that prevented the thermostat contacts from from working properly when you installed the thermostat onto its base plate. In any event, it is now working.
    Thanks.
  • 34 Answers
Sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Posted on Nov 12, 2008
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
I have a Honeywell programable RTH230B. I changed
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jan 08, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Honeywell RTH230B will not call for heat.
On a call for heat an internal switch should connect Rh and W, if it does not the stat is bad. Try it with no wires connected.
May 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Can't Program Clock for Honeywell RTH230B Thermostat
After you set the hr, min, and day, press the mode button.
Oct 05, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Feb 03, 2008 | Honeywell Programmable Thermostat Heater
RTH230B Thermostat
the transformer may be installed remotely to the furnace or may be a part of the honeywell burner relay. if you connected the thing between the transformer secondary common and hot it will surely blow the transformer.
Jan 31, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
675 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
