Question about Thumper Maxi Pro
OLder model Thumper Professional
Hi I recently sold my old thumper pro that I bought back in 96-97. I used it approximately ten times and have noot used it in a number of years. Before I sold it I plugged it in and made sure it worked and also plugged it in and started it to check and make sure the variable speed function operated. The lady a shopped and sold it too contacted me stating she was unhappy because when she starts it something hangs up but if she jiggles the black plate it works fine. I am not sure if something happened in shipping or not but I also recall some models requiring a tapping to engage the drive. Any thoughts on whether this as a problem or a normal thing? Thanks
2 Suggested Answers
kapishtech
  • 2272 Answers
SOURCE: Thumper mini-pro:switch does not working
This happens when the internal connections of switch are faulty or broken.
The unit needs to be opened and the panel behind the switch needs to be cleaned and the connection should be rewired.
Also check if the switch moves freely. if its jammed or stuck down then clean the switch surrounding and refit the switch. Its easy to do job and you wont require any special tool, Just a basic screwdriver is enough.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 06, 2010
Where can i get a thumper mini pro repaired?
Actually, you can remove the switch without opening the case, by simply carefully prying off the switch (which is actually a switch cover)
and then pushing the retaining clips of the "real" switch itself until it comes out. Then inspect & clean, and see if that solves your problem.
Another possible cause might be blown circuitry in the over-heat limiter.
May 20, 2014 | Thumper Mini Pro 2 Massager
THE TWO MASSAGE BALLS BROKE INTO ON THE THUMPER MINI PRO 2, HOW CAN I GET A REPLACEMENT
Call the company. They are very good for replacement parts, if you plan on DIY: Otherwise, they discount a replacement unit.
Apr 08, 2014 | Thumper Mini Pro 2 Massager
Thumper mini pro stopped working while in use?
Did it ever restart? If your'e not aware, there is an overheat prevention that will shut down the unit after prolonged use.
Apr 05, 2014 | Thumper Mini Pro 2 Massager
Missing one black rubber knob that fits over one of the two massage posts.
You can try the manufacturer for the replacement part. Their number is 1-800-THUMPER (848-6737). If you need a new massager, try Chiropractic Consignment at http://chiropracticconsignment.com/massagers-and-accessories/
Aug 24, 2013 | Thumper Min pro Ii Massager, Three...
Where can I get the purple plastic pivoting assembly for my mini pro2 thumper massager
best to call the company & see if they have it available as a repalcement part.
Sep 06, 2012 | Thumper Mini Pro 2 Massager
Thumper will not massage
clearly you'll have to disassemble to determine the problem (if not done already). For instructions, check 'thumper repair'
Apr 24, 2012 | Thumper Mini Pro 2 Massager
There is a long delay before the massager will acturally start to vibrate. Is this something that can be repaired?
The switch contacts are probably dirty. If you pry off the switch (actually it's a cover), you will see the actual switch underneath. There are several sets of contacts that control the speeds. Use a cotton swab wetted with 91% rubbing alcohol and clean the contacts. This made my Thumper work like brand new again. My is an older unit, and has open switch contacts. The newer models may have a different switch. This procedure was recommended to me when I called Thumper about my Mini Pro 2 not working properly. You can reach them at 1-800-848-6737.
Jul 12, 2010 | Thumper Mini Pro 2 Massager
Adjustable speed not functioning
The switch contacts are probably dirty. If you pry off the switch (actually it's a cover), you will see the actual switch underneath. There are several sets of contacts that control the speeds. Use a cotton swab wetted with 91% rubbing alcohol and clean the contacts. This made my Thumper work like brand new again. Mine is an older unit, and has open switch contacts. The newer models may have a different switch. This procedure was recommended to me when I called Thumper about my Mini Pro 2 not working properly. You can reach them at 1-800-848-6737. They are very nice people,and can probably help you fix the problem.
May 23, 2010 | Thumper Mini Pro 2 Massager
Thumper Maxi Pro Logo
56 people viewed this question
Top Thumper Health & Beauty Experts
john h
Mai Lor
Are you a Thumper Health and Beauty Expert? Answer questions, earn points and help others
