Default settings for Philips Magnavox TV
Hi
I have an older Philips Magnavox Smart SeriesTV and need to set it to the original default setting. I do not have the manual. Thanks
I bought another TV
Posted on Nov 12, 2008
Philips Magnavox 27MS343S 27" TV picture stretched or zoomed !
Take of the back and there is buttons inside, try turning them.
Nov 25, 2013 | Philips Magnavox 27MS343S 27" TV
Magnavox tv model # 13mt1532-17. Need code to disable the smart lock system. Can you help?
Hello
I assumes that you did gorget the code that you have set to Smart lock, and posts this solution.
If you ever forget you smartlock code, enter [ 0,7,1,1 ] code is the factory default, and can be used to enter and create a new acess code. OK.
Feb 10, 2012 | Televison & Video
I can not change my tv back to default settings I have lost all the manuals and them sort of things, I have a remote tho
This tv remote u have is the tv original remote?Yes.Just push the tv remote button said menu.Just go to each setting go down to do a resetting.That will be resetting back to all the default settings on the tv.
Apr 02, 2011 | Philips 42PFL5332D 42 in. LCD Television
DVD and older magnavox TV
On most of the older sets the video input is found by channeling down below channel 2 where you will find the video input source.
Nov 23, 2009 | Philips DVP3140
Somone set the smart lock on tv dont know the code
This information was found on the Magnavox customer support website. http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals It is located in the pdf copy of the owners manual on page 23. If this information does not help you solve your problem you can call Magnavox customer support at this telephone number 1-800-705-200. Give them the model number of you television and the problem you are having the smart lock feature. They will be able to help you solve the problem. I hope this information help you with you problem 1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- to highlight SET.
3 Press CH+ or CH- to highlight
PARENTAL CONTROL.
4 Press VOL+ or VOL- to display the
SECRET CODE screen.
5 Press VOL+ (on the remote) and the
CH+ button on the front of the TV
at the same time.
6 Press the Number buttons to
enter a four-digit code. The code will
appear on the screen as you enter it.
The code “0000” is the default of the
TV. If you have not set up a code previously,
then “0000” is the code.You cannot
use “0000” after you set your own
code (unless you reset the code to
“0000”).
7 Press MENU to save the code.
8 The Parental Control menu will appear
next. Press TV/AV/EXIT to remove
the menu, or continue from this point
to change your Parental Control settings
Apr 05, 2009 | Philips Magnavox 27MS343S 27" TV
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
Hi!
I have a user manual in norwegian, and I have just solved this problem. Go to page 107 in the user manual, and it will guide you. :)
Feb 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox mrv640-accidentally turned on progressive scan
Had exactly the same problem. You need to reset the DVD recorder to it's default setting. The default is "interlaced".
From the users manual.........
Switching the DVD Recorder
Disconnect the recorder's power cord.
2 Hold down the FF button (arrow pointing left) the front of the DVD Recorder while
reconnecting the power cord. 'PRO' (progressive scan) will appear
on the display.
3 If you want to switch back, repeat steps 1 and 2 . 'PRO'
(progressive scan) will disappear from the display. The DVD
Recorder is switched to 'Interlaced.'
The manual is at:
http://www.m4c.magnavox.com/files/m/mrv640_17/mrv640_17_dfu_aen.pdf
See page 12
It worked for me.
Mike
Jan 31, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Smart lock
If that function was put in use by the previous owner, the fastest way to change the parental lock out would be to contact your friend and get the access code from them.
Since the set probably uses a bit of flash memory to store the access code and other settings, if an individual chip, that would have to be physically removed and replaced.
If you can locate service information on your set, it will likely contain a procedure to set the memory back to factory default.
Jul 06, 2008 | Philips Magnavox 20MT133S 20" TV
Televison & Video Logo
467 people viewed this question
Top Televison & Video Experts
