Dim after bulb replacement
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
SOURCE: Epson PowerLite 83+ goes completely green or red
make sure the signal matches. you could reset the settings to factory default.
SOURCE: One of our Epson PowerLite projectors was working
We found that the bulb was dim because it was about to burn out. The projector's filter han't been kept clean, causing it to run hot, which in turn shortened the bulb's life.
SOURCE: How do I change the bulb in an Epson Powerlite 50c
hi there...
i found the complete set of instructions that you can follow to change your bulb. click the link
http://files.support.epson.com/pdf/pl50c_/pl50c_u1.pdf
you would need an adobe reader to open it, if you dont have an adobe program on your computer, download this one, its free
http://get.adobe.com/flashplayer/
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
SOURCE: How do I reset the lamp hours on an epson
EPSON PowerLite 7250 Reset
the lamp counter hours in 3 steps 1. Make sure, your projector is ON 2. Hold down the Help and Menu buttons
for 5 seconds. 3. Hold down the Tracking and Tracking -
buttons for 5 seconds.
The "A.S." screen will appear.
