Question about Dell (M1325) (64 MB) Graphic Card
Dell monitor power down mode with Geforce GFX card install
Hello, I run a Dell Dimension 2400, and for the past year have been using a Geforce 5600 GFX card with no issues. Yesterday I unplugged my speakers and the Monitor went into powerdown mode (with a message on screen of Monitor in power down mode , please activate using PC), no matter what i try to do , with keybard or mouse the Monitor will not come "online". I have also tried re-installing the GFX card, the Dell2400 comes with an integrated GFX card which has to be disabled to allow proper install, With the Geforce card out, the monitopr will power up, i can turn off and on the drivers for the integrated card , and the monitor will come online in either display mode. As soon as I plug in the Geforce card, whether i connect monitor to it or leave monitor in integrated port, the monitor goes into power save mode. I am at a loss , as to what to do, and hope sincerely that there is a simple trick/ something I am missing that you may be able to bring to light. thanks in advance
    President:
  • 2,961 Answers
I think maybe some how the main graphics for your pc has possibly switched to onboard. Try getting into bios F2 or DEl on boot up and highlight Advanced ChipsetFeatures and press Enter. In here make sure your AGP card is set as the Primary graphics controller. When done press ESC and 'Y' to save settings, then re-boot pc. Hope this gets you running again.
Posted on Nov 10, 2006
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
When i turn my computer on the power light and
If your computer turns on and your monitor stays in stand by mode, then there is no communication between your video card and the monitor.
You could check if the cable is plugged in correctly or even faulty.
It is also possible that there is a problem with your video card. Maybe physically uninstalling and reinstalling it could solve it.
If none of this helps, then you might want to check a new video card.
Hope this helped.
Nov 17, 2009 | Dell Dimension 2400 PC Desktop
What video card
i recommend a nvidia 9500gt 1gb vga card. It's phenomenal and purely insane graphics^_^
godlover
Jun 15, 2009 | Dell Dimension 2400 PC Desktop
Monitor going to power save mode and freezing
Hi, i have had that problem before and its wasn't the graphics card drivers, it was loose, anyway for you case go to device manager and uninstall the graphics drivers from there then restart and install then manual by updating and locate the exact location from the cd or any other location that has them.
That should help
Cheers
Apr 27, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Dell Dimension 5150 Stuck In Pwer Safe Mode
Sounds like a problem with the video card. Cross check the connections to the CPU. If its all fine, Then Connect the monitor to a diffrenet pc and then use the monitors keys to change it to a plug and play mode.This might help with ur problem
Feb 01, 2009 | Dell Dimension 2400 PC Desktop
Can a Dell Dimension 2400 take a GeForce 6600 graphics card?
This card can only Be installed in a Tower CPU. Your Card slot will not Accept this.
Jan 23, 2009 | Computers & Internet
Monitor is blank when plugged into Nvidia Geforce 8600GT
is video card pluged in tell bios pci express video snaped down good
Jan 19, 2008 | Dell Dimension E520 PC Desktop
Installing GeForce 5200 on Dell Dimension 2400
I suggest that better check that graphic card in another machine and make sure it is working.
Also find out the data transfer speed of your mother board through the AGP slot is compatible with your graphic card. (e.g. 4X, 8X, etc.)
If you are sure that your system really has an 8X AGP port (A choclate colored slot) then you could deffinitely install the card and work with it.
With the information I received the Dell Dimension 2400 deos not features an AGP 8X port, in that case it is not possible to install the card.
Then you should buy a new motherboard with AGP 8X Port to be able to install the Ge force FX 5200.
Nov 03, 2007 | PNY Verto GeForce FX 5200, (256 MB) PCI...
Computers & Internet Logo
123 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
