Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Moen bath valve is tight and wont shut off without holding knob i
I have a moen bathtub valve that is probably 30 year old and is very tight to turn on tand pops back out after water is shut off. If held in it will eventually stay off. Want to know how to fix problem. It is a single knob style with screws on cover plate directly across from each other.
  • 5,568 Answers
These are not only long-lived and reliable but also fairly easy to service.
Turn the water supply off!
The trim cover must be pried off (sharp knife slid under the edge) and then I think there is first a Phillips head that holds the knob on.
Our Moens always came with the necessary wrench to loosen the slotted nut but I think they are also included in the seal kit you should find at any chain 'home improvement' store. It's a simple stamped 'key' used for removing the nut.
I recall that the kits once had illustrations to guide you.
After cleaning up the cylinder and the piston that carries the seals ('O' rings) I have some silicone grease (not heat sink compound-it's gritty with zinc oxide) I use for reassembly; it makes them feel like new again.
With a gentle twist of the piston, slide the renewed assembly back into the cylinder and reverse your removal steps.
Posted on Nov 12, 2008
AquaSense by AquaGlass
The control & pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system will include the following items:
· New Pump
· AirStreme Control box and topside control
You will change out everything from the old system with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/0108-205005.aspx
US Parts Center
Nov 24, 2013 | Whirlpool Safety Bath Walk In Bathtub -...
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
When i move shower valve to hot, the water pressure drops. There is more cold water than hot. I have changed my moen valve before and this still happens. Good water any where else in the house including...
probably have a kink on how water line feeding valve..if possible to cut drywall bhind tub valve and inspect pipe at bottom plate...moen faucets are equipped w/ anti scald device, pressure balanced (newer models) and this could cause cold water to overwhelm hot water...
Nov 20, 2010 | Moen 3175 Legend One Handle Shower Faucet...
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
12 year old fiberglass tub originally white, now
home depot sell a bath tub remodelation kit.
it cost about $40 .
May 12, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
May 08, 2010 | Home
Compatible replacement handles for Moen Garden Tub faucet
I dont know if moen made chrome handles for that valve back then. If they did then they will probably be lever handles but they wont turn correctly unless you remove the cartridges and turn them. Iwould suggest probably replacing the whole unit.
Apr 20, 2009 | Moen Chateau, Two-Handle Garden Tub Faucet...
No hot water
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
John
Mar 15, 2009 | Moen Plumbing
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
213 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
