Question about Maytag Neptune MDE5500AY Electric Dryer
A slipping sound then a continued loud thumping noise
I have a LDE8404ACE Maytag dryer that is about 12 years old- It has worked fine up until the last month. It makes a loud slipping kind of noise as if the drum is lagging behind, then it moves into a more smooth sound but a still louder sound than usual - as if I'm drying gym shoes in every load. It seems to be louder now than it was a couple of weeks ago. I would appreciate any suggestions you might have.
  • brtmeadow Nov 15, 2008
    Thanks
  • brtmeadow Dec 07, 2008
    I had my dryer (LDE8404ACE) repaired by a Maytag certified repairman on Nov 24th and it was the blower wheel - the part was 303836, it cost me $26.55 for the part and $59.95 for the service call, $40 for the labor for a total of $134.72 with tax.  It was in the left lower corner at the front of the dryer. The blower wheel is seated on a "D" shaped post but the wheel had worn down to an"O" causing it to wobble.  It looked like a pretty simple repair process. Someone who is handy might be able to do it themselves. Good Luck!
I have the same dryer with the same problem, I am about to take it apart to diagnose, but from what i have researched, it sounds like it is either one of two things, the idler pulley bearings are shot, or some other bearing in the drive train. My wife reported this problem to me last night and i will figure it out today, if i do, i will post it here...
Posted on Dec 06, 2008
    Scholar:
  • 66 Answers
This could very well be the guide rollers in back of the cabinet. They will do this if there is considerable wear. They probably need to be replaced.
Posted on Nov 12, 2008
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer (LDE5914ACE) loud slipping/thumping sound
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
Mar 19, 2010 | Maytag Dryers
My GE tfx27f is working fine but when the
the thump ing sound is probably the rubber mounts under the compressor . they go hard and do not insulate the compressor . . pry the comp up on all four mounts and make sure they are loose and not stuck down if ther are hard and not bouncy .. replace them . if compressor has borken internal motor mounts / there is nothing you can do . but put up with noise ..
Jan 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Washer fills with water, loud thump sound, no agitation occurs.
The thump is probably the motor trying to start followed by the burning smell of the belt slipping. See if something is jammed, but the most likely thing there is a bad transmission.
Dec 31, 2009 | Maytag LSE7806A Top Load Stacked...
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Belt and drum turns but with a thumping sound.
check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Oct 03, 2009 | Maytag Dryers
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
Aug 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
251 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
