Question about Acer Aspire 3000 Notebook
Internal Speakers Are Not Found
When I shutdown my laptop (Acer Apire 3002LCi) and start it back up 90% of the time the speakers don't work. I have to go to the trouble shoot which tells me to delete the speakers and reinstall them ... Every time! ... It get's annoying!. Is there anything I can do ... myself... to stop this? Thanks Erin
    President:
  • 2,961 Answers
When you say you have to re-install them, are you actually installing the sound drivers from the acer restore programme or cd, or are you just letting windows find them(the sound driver) each time you go through the process of deleting them. Try installing drivers from the acer website to see if there is any newer driver versions http://support.acer-euro.com/drivers/notebook/as_3000_5000.html If it continues, you may have to restore the original laptop settings back to factory default, assuming it hasn't done this since the day of setup, but make sure you back up all settings and documents to cd or dvd first.
Posted on Nov 10, 2006
My Acer laptop won't start up well
Computer speaker is not working!! connect an external speaker,check how is the sound if it is working fine,need to replace the internal speaker, if the external speaker is not working too need to replace the sound card.
Sep 17, 2010 | Acer Audio Players & Recorders
My internal speakers for my Acer Aspire have suddenly stopped working. However, when I plug in my external speakers, there is not problem. Please advise. Thanks
Go into the speaker icon in the bottom right hand corner of the screen and click on it and get to the mixer. In there make sure the speakers aren't muted.
If it is muted then click on it to unmute it and you should have your sound back.
If you don't have your sound back then that means either the speakers are bad or because the internal speakers hook up to the motherboard, the mohterboard could be bad.
Jan 23, 2010 | Acer Aspire One PC Notebook
Headphone jack on Inspiron 1300 intermittent- suspect software
Check mixer on pc to ensure all levels are maxxed. Suspect moreso that plug on side of pc is bad. If this is helpful, please post as such
Jan 14, 2009 | Dell Inspiron 1300 Notebook
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
SPEAKERS NOT WORKING
hello
Try to check if your sound card driver is installed
AYADI
Apr 05, 2008 | Acer Aspire™ T180 PC Desktop
My laptop it having more problems...
sounds like a simple example of overheating on the laptop. Do you have it up off the surface, so that the air can get into the bottom or back fan?
Mar 19, 2008 | Acer Aspire 3680 Laptop
Acer 5610 sound problems
Hi, It is possible that: 1. You may have recently installed an add-on/external device such as a multimedia keyboard which changed the audio output from internal to external; 2. The laptop's internal speaker might have gone dead (highly unlikely but still a possibility) - try plugging in external speakers or a headset and check; 3. Most if not all laptops uses a female stereo babyphone jack to connect to external speakers. This jack has a built-in switch that cuts off internal speaker if an external is plug in. If you are using eternal or headset from time to time, it is possible that the switch might have locked to external and does not switch back to the internal; 4. You may have a hardware issue specifically the sound card/chipset. This of course would require an inshop repair which may be better off with an authorized service center. At worst is have the entire laptop replace if it is confirmed to be a hardware issue. Hope this be of some help/idea. Post back how things are or should you need additional information. Good luck and kind regards.
Sep 09, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
300 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
