Question about Maytag Kitchen Ranges
Maytag range shows F1 - Maytag Kitchen Ranges
  • 60 Answers
F1 means the electronic control module (clock assembly) is faulty
Posted on Nov 12, 2008
Display panel shows F1 Fault... how do I fix this
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 01, 2010 | Maytag MGR5750 Gas Kitchen Range
F1-1
Hi
Thanks for using FixYa. Error code F1-1 in your Maytag Gemini Indicates runaway cook in upper oven and to resolve this issue you’ll have to check the oven temperature sensor & replace if it has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 20, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Maytag electric range shows F1 error message and beeps every hour or so. we've checked the fuses and they seem okay.
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
Nov 12, 2009 | Maytag MER5770 Electric Kitchen Range
Getting E1 and F1 or F7 on my Maytag Advanced Cooking System
F1 shows on panel and fan is running, how do i turn this off - what does f1 mean?
Jan 31, 2009 | Maytag MER5775Q Electric Kitchen Range
Timer on the Maytag range keeps beeping and shows F1
the F1 code is usually an internal failure of the control board. it may have a failed oven sensor that is causing the control to think it is over temp and the sensor is alot cheaper to replace first, usually about 50 bucks. to replace the control board will usually cost about 150-200 bucks. but try the sensor first.
Dec 22, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag electric range shows F1 error message and beeps what does this mean? and now it permanently shows this message and not thee closk
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 03, 2008 | Maytag MER5770 Electric Kitchen Range
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
MER5730AGW Electric Range
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Aug 14, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
101 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
