Looking for scanning software that will work well with Vista 64, and a Canon MF 8180c. A printer driver came with a scanner driver, which works with paint. But I am looking for a ADF friendly software package. Any ideas?
Problem is, the toolbox utility (scanning) from canon is not recognizing my 8180c, even though i just dwnd fresh driver from canon for local printer. (toolbox is a wired utility.) so no answer, just bewilderment. used to work!..
Posted on Mar 18, 2010
How do i get canon imageclass mf 6540 to scan
Such printers with scanners built into them are know as Multi Function Printers. It is possible you have downloaded a 'printer only' or generic printer driver software.
Here are the links to the 3 bits of software you require:
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100242106EN.htm
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0200155901EN.htm
3 (only for 64 bit windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114601EN.htm
3 (only 32 bit Windows 8)
http://www.usa.canon.com/nw3s/CanonUSA/DownloadContents/English/0100114501EN.htm
May 05, 2014 | Canon ImageClass MF6540 Copier
How to get Canon MF toolbox to work with Win7 64bit.
I got mine to work. Just set the compatibility mode for the .exe file to Windows XP (Service Pack 2).
Jun 24, 2010 | Canon imageCLASS MF3240 All-In-One Laser...
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Canon MF 8180c - MFToolbox does not find scanner on Vista 64bit
Hi ...
As per my knowledge, MFToolbox does not work with Windows Vista 64 bit ....
But just to be absolutely sure about it, I checked for this information in multiple locations including canon official website but got the same answer ... it does not work with Windows Vista 64 bit ...
I know I can't help to resolve your issue ... But do vote ...
Cheers ... :)
Jul 26, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
I have pixma MP145. i want use my scanner corectly
you have to install the scanner driver & application in able to use the scanner to scan documents.
here is the driver for your scanner, download & install it.
Canon PIXMA MP145 Printer Driver 1.05 For Windows Vista(32/64)/XP
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Need a driver for my Canon series MF3200
The driver with my canon MF 3200 series does not compatible with my 64 bit vista laptop , also Canon MF Toolbox 4.9 does not respond because the message appear told me that the supported scanner does not installed
Apr 01, 2009 | Canon Office Equipment & Supplies
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Mar 30, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Can't scan with Canon MF printer with New 64 bit laptop
You might try "viewscan". there is a free trial, but the software is not free if you want to use it for long.
https://www.hamrick.com/vuescan/supported-scanners.html
Jun 05, 2017 | HP PSC 1410 All-In-One InkJet Printer
My scan is not prorerly working? Is coming an error "plz select the another application,this application is not found"
Hi dpknarwal,
In case anyone else would like to assist as well, please note that the model is Canon 8180C - on FixYa all questions are categorized according to the product model, so if it's not in the question, it's in the header above the question.
Now, to answer your question, have you installed the software that came with the machine? If not, do so now. If you have, try uninstalling it and re-installing it. Also make sure that the Canon is connected to your computer. Try unplugging the cable and plugging it back in. The instructions for installing the software are in the in the software guide, which you can find at this web address:
http://gdlp01.c-wss.com/gds/0900008039/imageClass_MF8180c_Software_Guide_EN.pdf
To scan on this machine, press [moz-screenshot.jpgmoz-screenshot-1.jpgScan], then [B&W Start] or [Color Start]. If this is the first time you've tried scanning with this machine, you may need to select a program to work with the scanner. Try selecting moz-screenshot-2.jpgMF Toolbox ver. 4.9 (or whatever version you have).
The other option is to use your computer to scan the document. Go to Start > Programs > Accessories > Scanner and Camera Wizard. If it finds the Canon, it will scan the document. If not, then the software and/or driver is not installed correctly. You can also perform this function with other programs on your computer, such as Paint (choose File > From Scanner or Camera...) or even Microsoft Word (choose Insert > Picture > From Scanner or Camera...) If the program finds your scanner, it will import the image. If it doesn't, then the software and/or driver is not installed correctly.
For your reference, the basic User's Guide for your Canon can be viewed at the following web address:
http://gdlp01.c-wss.com/gds/0900008008/imageClass_MF8180c_Basic_Guide_EN.pdf
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 15, 2008 | Canon MF8180C Color Laser MFC Printer
Problem in canon
i found a solution for printing with Canon MF 3110
1- Download Driver For MF5730/5750/5770 For Vista 64-Bit
File Name : L7602ENx.exe
http://software.canon-europe.com/products/0010260.asp
Follow These Steps
1- Add Printer
2- add a local printer
3- Use an existing Port : Choose : USB ( Virtual Printer for USB )
4- Have Disk
5- Locate the File Name : MF5700AK.inf
6- Printer Name : Change From Canon MF5700 Series To Canon MF3110 Series
7- Print Test Page
it Work for me on Vista Home Premium SP1 64-Bit
P.s
still Cant Manage to use the Toolbox 4.9.1.1.mf04 for Scanning ( Any Ideas ? )
Oct 22, 2008 | Canon MF3110 All-In-One Laser Printer
267 people viewed this question
jasbo
jasbo
