TIMING BELT
Removal
Disconnect negative
battery cable. Disconnect intake air temperature sensor connector from intake air duct. Disconnect the
air intake tube from the throttle
body. Disconnect the breather tube from the valve cover. Remove resonator from
throttle body. Remove
air filter housing.
Raise
and support the vehicle. Remove right front wheel. Remove right front
splash shield from wheelwell. Remove serpentine accessory drive belt.
Remove
crankshaft pulley bolts. It is NOT necessary to remove crankshaft sprocket center bolt. Remove crankshaft pulley. Lower vehicle.
Support
engine assembly from above with Support Fixture (J-28467-B). Remove engine mount bracket from
timing belt end of engine.Remove
power steering hose clamp bolt, and position hose away from
timing belt cover. Remove front
timing belt cover. Using
crankshaft center bolt, rotate crankshaft one full turn clockwise (as viewed from
timing belt end of
engine).
Align mark on
crankshaft sprocket with notch at bottom of rear
timing belt cover. See Fig. 4 . Align
camshaft sprocket
timing marks with notches on valve cover. See Fig. 5 .
CAUTION:
Engine damage could result if
camshaft sprockets are not properly aligned with notches on valve cover.
Loosen the automatic tensioner bolt. Use an Allen wrench to rotate tensioner and relieve tension on
timing belt. Remove
timing belt.
Fig. 4: Aligning
Crankshaft Sprocket
Timing Mark
Courtesy of DAEWOO MOTOR AMERICA, INC.
Fig. 5: Aligning
Camshaft Sprocket
Timing Marks
Installation
Ensure
crankshaft and
camshaft timing marks are still aligned. Install the
timing belt. See Fig. 7 . Turn the
timing belt tensioner
counterclockwise to tension the timing belt. Turn tensioner until the
pointer aligns with the notch on the rear timing belt cover. Tighten
automatic tensioner bolt to specification. See TORQUE SPECIFICATIONS .
Using
crankshaft center bolt, turn crankshaft clockwise (as viewed from
timing belt end of
engine) 2 full revolutions. Ensure
timing belt tensioner pointer is still aligned with notch.
If
timing belt tensioner is correctly aligned, install
timing belt cover. See Fig. 3 . Install the
engine mount bracket on the
timing belt end of engine. Position
power steering hose in place, and install clamp bolt. Install
crankshaft pulley. Install serpentine accessory drive belt.
Install right front splash shield. Install right front wheel. Install
air filter housing and resonator. Connect
air intake temperature sensor connector. Connect negative
battery cable.
Fig. 7: Identifying
Timing Belt Routing
here
http://www.2carpros.com/questions/daewoo-leganza-2000-daewoo-leganza-timing-marks
Yes?
