Question about Sharp 25VS-J250 25" TV
Help my tv will not turn off and can't get in menue
  • 24 Answers
Try unplugging for about 5-10 minutes. Do you have problems with static electricity?
Posted on Nov 11, 2006
SOURCE:
I have a jvc em32ts tv. Somehow the narration feature was turned on and it will not turn off. How do I turn this off
Are you sure it's turned on through the tv and not a cable or sat device or maybe vcr? If you cannot access the feature it may not be on the tv. I would see if you can call uip the menue onthe tv and search through the menues area to find the Closed Caption Or Text dis[lay.
Oct 30, 2014 | JVC Emerald EM32T 32" 720p LED-LCD TV -...
Turning off close caption on xfinity tv
The Comcast boxes let you enter a special menu only when the box is turned off. Just turn off the Comcast box and press the menu button on the remote you will then see a menu for the box where you can turn on and off close captioning
/uploads/images/turning-off-close-caption-xfinity-tv-35300106-2-1.jpg
/uploads/images/turning-off-close-caption-xfinity-tv-35300106-2-2.jpg
Mar 13, 2013 | Comcast XFINITY
MY TV SUDDENLY TURNS OFF, AND SUNDDENLY TURN ON AT 3:AM. WHAT I CAN DO???
The Sleep Timer of your TV has been made.So try to find out yourself coz I could not find out the exact Menu.Thanks
Jul 15, 2011 | LG 42LC2D 42 in. LCD HDTV
I have an older model sansui tv with out original remote. Somehow captions were turned on and I can't figure out how to turn them off. Help asap!
Ur tv have a button that said Menu on the bottom tv beside buttons only said POWER,CHANNELS + -,VOLUME + - ?Used the tv menu button go through the options functions look for Close Caption find CC 1,2,3 or TEXT 1,2,3 turn it all off,will stop captionning,if tv have no Menu option button.The captionning can be turn off by an original remote only.Try website like Remotes.com to buy the tv original remote.
Apr 27, 2011 | Televison & Video
Blue menu screen stays on
Hi! the blue menu screen can be turned off by pressing the same button that caused it to appear. In most cases pressing the "Menu" button on the remote or TV-control will make the blue menu screen disappear..
I hope this helps!
Mar 10, 2009 | Zenith C27A24T 27" TV
Default input when turning on the TV
From the menu select Option, then select Input Select, then select the signal type you want to use on startup, set to Auto, then press menu to exit. let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 12, 2009 | Sharp LC-42D64U 42 in. LCD HDTV
I have a Samsung LE26R72B. the digital tv has just stopped working. the digital screen has frozen with 'FILM 4' on it. i can't acces the digital menu and i cant change channel. all other features of the tv...
Solution that worked for me:
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jul 07, 2008 | Televison & Video
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
