Question about Samsung AW1203B Air Conditioner
Samsung cassette air conditioner keeps switching off
Hi I have two Samsung AVXCM casette style ac units and they both switch off automatically after running for a couple of minutes. Both the fan and the timer light come on when the units cut off? Any ideas what might be causing this?
Many thanks
  • mark_jackson Nov 13, 2008
    Why would this effect both at the same time?- if it only effected one then I could understand however its the same for both. I would think its unlikely to have a problem with the thermostst in both at the same time?
    President:
  • 1,952 Answers
You can set this timer to the length of time you want to wait for the air conditioner to come back on from .03 of a second to 10 minutes. What this timer does is delay the amount of time you want your air conditioner to come on when low voltage power is applied to the timer. This low voltage timer is simple to install. *Some of the new thermostats have this delay feature built into them. If you have a thermostat that has this delay feature. If you want to protect your air conditioning system from short cycling and possible compressor damage, then the Delay on Make timer is for you! Please remember to turn off all power when working on air conditioning equipment.
Posted on Nov 13, 2008
  • mohammed marika thambi
    mohammed marika thambi Nov 13, 2008
    You need to solve this problem
    by purchasing a new contactor
    You will need to call a service technician to charge up your system if
    it is low. Now EPA require that you be licensed and certified to purchase and
    use refrigerants.
    5.
    Inspect your wiring to make sure that you do not have any burnt connections.
    Repair the burnt connections if you have some.
    6.
    Inspect the capacitor/capacitors to see if they are swollen looking. If they are
    swollen purchase a new capacitor from our capacitor
    7.
    Take the compressor terminal cover off and inspect the terminals on the
    compressor.
    Brigadier General:
  • 6,966 Answers
Offhand, I would have to agree that it is highly unlikely for two units to exhibit identical symptoms/faults in the same time frame. Might it have been an external factor? Was there anything out of the ordinary prior to the fault? Power interruption/outages, thunder storm or near lightning strike, any continuous rain lately, or anything noteworthy. Perhaps you could try a hard reset if the units have such a key/button/feature or simulate a reset by unplugging from the mains for an extended period of time. Incidentally, it may be worth your while to have the voltage checked at the outlet themselves.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development(s) so far?
    Sergeant:
    Champion:
  • 283 Answers
Basically, you are right. Its the thermostat that cause automatically switch off your unit. If you could open the thermostat panel then open it. the adjustment of it might lossen. try to tight it back.
Thank you for using fixya..Please dont rate me if you are not satisfied with my suggestions..
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
try to check the termostat and the compressor
    Genius:
  • 1,847 Answers
There seems issue withe the thermostat.
  • Legin Varghese
    Legin Varghese Nov 13, 2008
    Get the thermostat checked and it seem the only issue which cuts of the compressor and the fan. let me know if you need more information...kevin
  • Legin Varghese
    The other thing I feel is some IC which stops working after heating up in the control panel.
    you can get the control panel check which also has the thermostat unit.
I have a samsung split system it's just shows error 6 and dosen't work .. It's the perpendicular style.. Please answer my question ...
Fault code. 6. From what I have read 1 of 2 items. The unit has completely lost freon charge. Or 2, outdoor has overheating problem, ie. condenser fan motor not running
Aug 01, 2013 | Heating & Cooling
Hi My Carrier AC getting switched off automatically after two minutes.. Please help me
Your unit is probably going out on high limit. This could be caused by a bad condenser fan motor. Check to see if the outdoor unit is dirty. If it is, take a hose and wash the coil. It the coil isn't dirty, you really need a qualified service person to come take a look at this.
Jul 28, 2011 | Carrier 36KCARMS Air Conditioner
My ac keeps showing up a code :c4. is still blowing air but not cold?
c4 SplitVRV ac unit, ceiling mounted cassettes, Sensor misplaced. Please find sensor and keep it right place. Thanks.
Feb 04, 2011 | Heating & Cooling
AQV12FAN
it sounds like a program feature once the unit reaches a certain temp it automaticly turns it self back on check program guid
Apr 08, 2010 | Samsung Heating & Cooling
Hi,mitsubishi ms12tn mini split ,when i put on the
There is small PCB in the AC, this PCB is malfuctioning also there is automatic ON /OFF switch Check whether ti is working properly or not.
Oct 02, 2009 | Mitsubishi MS12TN Air Conditioner
SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Sep 02, 2009 | Samsung Heating & Cooling
Ac unit reset switch keeps popping out
is this a switch that is built on the cord .if so by pass the switch, or you could buy a new cord.
May 25, 2009 | Haier HWR08XC7 Air Conditioner
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Trips when plugged in
AC pulling to much power from outlet. Thus tripping the switch.
try to remove all that is plugged into this outlet and have only the AC plug into the outlet.
If you live in an apartment, there might be a dedicated plug for AC. Ask the super.
Jun 30, 2008 | Samsung AW0603B Air Conditioner
Samsung AW1203B Air Conditioner Logo
85 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
