Question about Palm Tungsten E Handheld
USB device not recognized or has malfunctioned on hotsync
I replaced the battery in my Tungsten E and now when I try to Hotsync I keep getting an error in my system tray that the USB device is not recognized or has malfunctioned. I tried installing the software on another computer and I still get the same message. I have installed all the curent software and still can't HotSync. I have Motorola phone tools and the same USB connection recognizes my phone. Guess my battery replacement made my Tungsten E toast?
Don't try the PAlm Website: They provide you with a straight ignore. Mine hung up on me two years ago and there was not even an acknowledgement of my enquiry. Stay AWAY from anything Palm.
Posted on Feb 24, 2007
I finaly solved my problem. After numerous hard resets and searching PDA blogs I concluded that what caused my problem was the battery installation. Consequently I reopened my Palm device, De-solderd one of the battery wires, left it disconnected for a bit and then re connected it. After that I was able to hotsync my device like I had before
Last week, windoze started barking the same complaint at me. A hard reset (of my Tungsten E) solved the problem. Caution: A hard reset (keep the power button pressed while performing a normal reset. Only release power button, when Palm logo screen appears. The press up-key) delete ALL data (even the identity, i.e. hotsync ID) from your palm - so be sure to have a recent backup!
Posted on Jan 30, 2007
SOURCE:
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Palm tungsten 3 will not hotsync. b/c port is already in use.
A friend helped me fix the problem. Your site was advertised as free, but it was not. Shame, shame.
Aug 07, 2009 | Palm Electronics - Others
Hotsync not working right
I keep playing with it and then saw I was on the wrong person (on the computer) for hotsync, can you say duh!
May 11, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten V
Re-arrange port configuration, install latest version of palm desktop. Right click on palmsync icon on system tray and check "Local Serial" . You may also use IrDa as alternate sync method
Apr 04, 2009 | Palm Tungsten E2 Handheld
Palm tungsten
you may want to run through a few troubleshooting tricks
first try pulling out any extra USB type items that you remove and replace frequently (like a flash drive) and restart your computer after its done booting up you can try hotsyncing again. Make sure what you wanted to put on your PDA is still in the Hotsync manager box.
A PDA not wanting to hotsync is a very general statement. It is an indicator for many different problems.
-You may need a new hotsync cable
-try a different usb port on your computer
-you could open the PDA up and check if all the contacts are clean and connected (Warranty void alert)
-Try re-installing the PAlm desktop software
-If nothing else works put whatever application you're trying to hotsync onto a SD card and copy it from the card and onto the PDA
Tungsten Es are excellent PDAs and it doesn't have too many problems besides being too "basic". A problem like not hot syncing probably isn't an indicator of something really bad unless you've dropped it too many times.
If all else fails you may need to pick up a different PDA
Jun 19, 2008 | Palm Tungsten E2 Handheld
Can not find an available Com port for Hotsync
Right click on the Hotsync icon in the taskbar (usually at the bottom-right hand corner of the screen) and select "USB" sync, while unchecking "Serial" or "Com" options. Then, initiate the hotsync from your palm handheld, rather than computer. Hopefully this will help!
Oct 07, 2007 | Palm Tungsten E Handheld
HOTSYNC REQUIRES RESET
HotSync menu select Custom, change System to HandHeld overwrites Desktop, set as default. It is probably set to Desktop overwrites Handheld
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
HotSync Outlook 2003 with Tungsten E
I tried all the suggestions that were offered and gave up. But then out of pure craziness I loaded the treo 600 CD that came with my Treo 600 out of curiosity. It loaded and the MS Office 2003 conduits loaded nicely and the problem appears to be solved for now. So I tested and it the Tungsten E Hotsync's feature all appear to be okay. I'm not sure if this is the best solution but it solved a very frustrating problem. The version of Hotsync that loaded is 4.1.0. Hope this helps.
Sep 11, 2005 | Palm Tungsten E Handheld
Palm Tungsten E Handheld Logo
154 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
