Question about Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
Well, it leaks all of the water out of the bottom during the draining period after the wash. It seems to be coming from the bottom. I was told to check the soap drawer for clogs. It isn't. Any other sugesstions? door is leaking at bottom on rinse cycle, seal is in good shape and so is the door wondered if water could over fill, didn't leak on smaller loads
  • 685 Answers
Hi
the first thing you want to check is your level that your washing on low medium or high load.
make sure your setting it to the right water level setting.as for the water comming out of the bottom you might want to make sure you don't have a hose loose or that it is leaking.the tub on the washer could also have a leak in it so check those things.
thank you
juanita
Posted on Nov 12, 2008
    Sergeant:
    Novelist:
  • 196 Answers
Check out the hoses are they properly tight.
  • mmechanics Nov 12, 2008
    Check the easy stuff first, fill hoses tight?- drain hose
    cracked?
    Failing those checks, cut a piece of
    cardboard slightly smaller than the size of your washer. Slip the cardboard
    under the washer and run a short load. Look carefully at the water mark on the
    cardboard. The mark on the cardboard the water leak will leave, will help you
    tell from which side or front to back the leak is common from. This will help
    point you in the correct direction to look for the trouble maker.
  • Whirlpool Master
  • 19,396 Answers
Check the drain hose and drain pipe for leaks also the drain pump itself may leak.
  • Ginko
    Ginko Nov 12, 2008
    Check the drain filter first.
    1 Since the machine leaks during the drain cycle only (that is what I
    understood) the most likely is a problem with the drain lines.
    Teh repairman will access the inside of the machine, and inspect the drain lines to see where the leak comes from.
    The drain hose can also be obstructed, you can blow some air into the drain hose to see if it is clogged.
    The drain pump is faulty and is leaking. A faulty drain pump can leak,
    this can also explain the two pints of water. Again, there is the need
    to observe the pump and see if it is leaking. The pump is mounted on
    the lower side of the appliance, watching ftom the front on the right
    side.
    3 The machines is overfilling and it is leaking some water
    from the main tub gasket. I do not think this is the case, but it is
    also a possibility.
    Here you find generic schematics.
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Drain hose seal leak on Kenmore washer
Remove the hose and bend it in circiles see if yo see any cracks in the hose if you do replace it or if it's long enough cut out the bad part and replace it. Alos clamps wear out ver time so try replacing the clamps too.
Jul 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leak well after completion of wash cycle - Neptune Front Loader
peace,
ngafm1 at your service,
Water sprayed out of ( the leaky washers in the hot water shut off valve which need to be replaced.
They are inside all valves and wear out in time from normal use!
Or you can have a bad solder joint at the junction between the hot water shut off valve or the the pipe joint!
these washers in any shutoff valve can leak intermittently till they get worse and then leak all the time!
you should be able to stand there and watch it as you open and close the shut off valve again and again , and then stay there and watch it start leaking!
Or when you are opening it and closing the valve 4 times straight you may feel a trickle of water from the valve stem!!!!
This means washers in the valve stem need to be replaced!!!
Get a new plumber !!!!!!!!!!!!!!!!!! I'm no plumber but I do under stand this!
Bless You,
please give me a good rating here at fixya.com before you sign off!
Aug 01, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Neptune washer
check arround the rubber bellows that the door seals aginst, maybe a hole in it, could be a pump leak drain hose leak
a lot of could bees i know but one of these
Apr 09, 2008 | Maytag MAH6500 Neptune Front Loading...
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Front Loading HE washer is leaking! Hellllp!
hi there i would check the softner part of your soap drawer first for blockages, you can let me know
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
178 people viewed this question
Dan Webster
Dan Webster
Sal De
