Question about Dell Microsoft Windows XP Home Edition
Dell laptop latitude x300 won't boot up
I dropped my computer yesterday, then shut if off for a while, then turned it back on. When I turned it back on, it seemed okay, but then went to a screen that said something about dumping memory. Wasn't really paying attention so can't really say what was going on. Ever since then, my computer just does the same thing over and over. When I turn it on, it comes to a screen that says "Dell" in the middle, with F2 for setup or F12 for boot up. If I don't hit either button, the screen goes away after about 5 seconds and then says "Disk error occured, hit ctrl + alt + delete to restart."
If I hit F2, it takes me to the setup screen which I'm not sure what to do with that. If I hit F12, it takes me to some boot up screen I guess, which again not really sure what to do with that. Anyway, I've tried loading the drivers and utilities disk, but they don't work. I'm pretty computer illiterate when it comes to **** like this. Any help would be greatly appreciated. I went out and bought another laptop today, but there's so much on my other laptop that I would like to be able to retrieve if I can before I trash it.
Oh, I think I ran a diagnostic and when it gets to the test after memory, it says it failed, some partition not found, load the drivers and utilities disk and hit okay. I do that and then it says "disk error occured, hit ctrl alt delete. I'm not even sure if the drivers and utilities disk I have is the right one other than it says Dell.
  • dlpinvestor Nov 12, 2008
    "You could try to remove and reseat the hard disk drive and see if that works"
    How would I do that?
    Removed the hard drive and put it back in, but it just says disk error, hit ctrl alt delete.
  • Dell Master
  • 998 Answers
Your laptop hard drive is probably damaged from the fall. The reason why diagnostic test after memory fails is that it’s trying to load from the “Diagnostic Partition” which is located on your hard disk drive. You could try to remove and reseat the hard disk drive and see if that works, otherwise you’ll have to take the drive to a local computer repair shop to see if they can retrieve any data.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 12, 2008
My Dell Latitude x300 will not turn on at all. Before that a blank sceen of blue black appeared then the computer completely shut down. How can I Fix this?
If NO display at all then the problem with the motherboard, especially Display Chip(graphics). If it shows the opening dell Logo then remove the RAM and replace with new one. best of luck. and keep smiling
Jan 19, 2011 | Dell Latitude X300 Notebook
I need to remove bios password from dell latitude x300
Hi there !
You can remove the BIOS password by removing the CMOS battery located inside your laptop and in the motherboard. Turn off your computer and remove the battery before opening the computer and remove all the screws at the back of your laptop to reveal the motherboard and remove the battery.
I hope it helps you. Good Luck
Jan 10, 2011 | Dell Latitude X300 Notebook
Dell latitude x300 port usb not detect
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 25, 2010 | Dell Latitude X300 Notebook
Yesterday my dell latitude x300 started to boot up then went to a blue screen that says "unmountabe_boot_volumn. What do I do to fix it?
It's called the Blue Screen of Death. Did you install any software before it happens? If you does, try to restart your laptop then login in a Safe Mode, then go to Control Panel - Add/Remove Programs - then unistall it then restart. But if you didn't install anything when it happens, just restart your pc. If it still went to the BSC, try reinstalling your OS. Hope it helps!
Jul 19, 2010 | Dell Latitude X300 Notebook
My Dell Latitude x300 monitor is dark (black) while the computer is running. I plugged it into a stand alone monitor and it was also black. how do it fix it.
Your graphics card adapter is damaged!
buy a new card to your dell laptop
and let someone with experiense change it.
This is your solution! Please vote!!!
Feb 28, 2010 | Dell Latitude X300 Notebook
I need a multimedia-audiocontrolller for my Dell Latitude X300 !!
Hi:
If you go to :
www.dell.com
click on the support link, then drivers,
type in your service tag number for best results, or you can use the model number. You can then download all drivers available for your machine!
Dec 16, 2009 | Dell Latitude X300 Notebook
I need instructions on soldering a dc jack on my latitude x300 laptop
OK the first link is for the DC jack repair and the second link is a service manual for your laptop. Just copy and paste them into the address bar of your browser. Be sure to save a copy for yourself as a reference. Good luck
ParrotHead PC Repair.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/comment-page-9/
http://www.elhvb.com/mobokive/edwin/laptops/Dell/LATITUDE/X300/X300.PDF
Sep 09, 2009 | Dell Latitude X300 Notebook
My laptop can't play . I've a sond's problem on It.
check if you audio driver is properly installed. to check click windows start, point to computer, right click computer, manage then click device manager. if you see an exclamation point this means that driver is not properly installed. uinstall it first then install it back again.
May 18, 2009 | Dell Latitude X300 Notebook
Computers & Internet Logo
814 people viewed this question
Alun Cox
