Question about Canon imageRUNNER C3200 Color Printer
Canon imagerunner Ir c3200 total reset
I purchased a canon ir c 3200 from a large company which had it setup on a large office network with their own IP address and other settings etc.
Therefore when I plug it into my network it does not communicate at all.
How do I reset and erase ALL settings on this printer to restore factory settings?
Thanks for your help
  • 149 Answers
Ok. Press the additional functions key - that is they key with the star inside it - then select 'system settings' then 'network settings' then select 'ip setting'. Once you've got into the ip settings you can enter all your own network settings. All you need to enter is IP address, subnet mask and default gateway but you'll know all that.
Posted on Jul 06, 2009
  • 31 Answers
Ok my what you need to do is first go into service mode by pressing asterisk key(*) on control panel and then press2& 8 simultaneously on numeric key pad and press asterisk key again.Other screen will appear with following main screen: copier.sorter,feeder,etc.Go copier another screen will appear go to function touch it then go to clear all then switch off machine then on again.In this way you will have cleared them ram then do paper size registration by going to CST intermediate screan put different sizes of paper in the ADF one at time keep pressing ok for each size selected.After you are through exit service mode by switching off machine.
Posted on Aug 22, 2009
    New Friend:
I hv irc3200 is showing replace toner but i have full set of toner in it please help me out
Posted on Jul 01, 2014
    New Friend:
Hi i am using canon ir2420l all in one printer.i set the id password also but unfortunately the password is missing. now how to login the printer
Posted on Sep 23, 2013
    Problem Solver:
  • 10 Answers
I have my Ir c3200 but i cant find the IP add different from the other IR 3200 you can easily find the Ip add how can i fix this.... pls help
Posted on Apr 27, 2010
I own this copier and im trying to hook it up to my network. when i go to the network settings pages the only thing that shows up is the tcp/ip setting. After i select this option there is no other option to help me adjust the network settings on the printer. any help would be appricated, thanks
Posted on Dec 15, 2009
    Problem Solver:
  • 7 Answers
Dear;
You can easily go from the screen to the setup menu into the network setup. You can do it yourself without being an expert,and thre you simply change the IP address, submask, Getaway, without resetting he machine.
I do not advise resetting the machine to factory default especially if it was used and parts like drum,... were changed before you own it.
Good luck.
Posted on May 08, 2009
2 Suggested Answers
  • 2692 Answers
SOURCE: canon imagerunner Ir c3200 total reset
Here is the Canon support website. If you can find you model , you can download a manual which contain all the information that you need.I coundn't find it because I dont know enough about you printer. Ink? etc.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Posted on Jan 20, 2009
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
Need How-To on calibrating Canon IR-3200...
try under user mode (add.function) cleaning or similar and auto calibration, it will print out 4 test that you need to scann on copier, you just follow the copiers instruction
Sep 14, 2009 | Canon imageRUNNER C3200 Color Printer
Canon ir c3200 copies are shake what i do
Is the copier making a load noise? You may have a broken driver gear in the fixing unit.
Apr 05, 2009 | Canon imageRUNNER C3200 Copier
I have toner of Ir 3100 but I want to use in ir c 3200 is it
Well toner compositions change to work correctly with different developers. If you use the wrong toner/developer in your machine you WILL need a tech to de-contaminate your machine at a hefty price. That is why the manufacturer makes the bottles different, so the customer cannot use the wrong toner in the machine. DO WHAT YOU WILL.. But I advise Strongly against it.
Apr 03, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
IR C320N scaning with MAC OSX
Use the Irc 3200 drivers on the Canon USA
Color imageRUNNER C3200 : Drivers & Downloads
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=8927
Feb 08, 2009 | Canon imageRUNNER C3200 Copier
On the Control panel press asterisk (with the head) next to ? mark the press the ID SYSTEM SETTING>NETWORK SETTING>TCP IP .you can reset or erase the IP Addres or if you know to go to service program :COPIER>FUNCTION>CLEAR> MN-CON then switch OFF and ON the machine it will restart and then the machine will asked to switch ON/OFF theunit then all are reset
Jan 20, 2009 | Canon iRC3100 Printer
Canon ir c3200 promts for page setup on each internet document
I believed when page setting box show out you have to enter the quantity you want print
Dec 09, 2008 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Color Printer Logo
4,279 people viewed this question
old marine
old marine
