Question about HP Office Equipment & Supplies
I have a HP photosmart C3150 all-in-one copier/scanner/printer. I changed both ink cartridges on Sunday and when I closed the door the cartridges moved to the left and are stuck there. How can I fix the problem? Barbara Johnson/ jeanbabs57@cox.net
  • 2 more comments
  • jeanbabs57 Nov 12, 2008
    I am unable to remove the cartridges because they are STUCK on the left hand side. i already tried that.
  • jeanbabs57 Nov 13, 2008
    I am unable to get to the cartridges because they are STUCK way to the left side of the printer. I tried to reach back there but am unable to budge them. and they are way back. Any more suggestions?
  • jeanbabs57 Nov 15, 2008
    I cannot accept your solution because I am unable to get to the cartridges to remove them because they are STUCK to the left of the printer. When printer is turned on tere is a clicking noise which sounds like the cartridges are trying to move dbut are STUCK. This is my second response to your first solution. Please e-mail me: jeanbabs57@cox.net
  • HP Master
  • 1,879 Answers
You had probably checked inside the printer for any obstructions. A hardware reset won't help because of the mechanical failure.
Manually moving the print head will further damage the unit. It needs service from a QUALIFIED technician.
But you can try it if you want to and take the risk of rendering your printer completely useless.
Posted on Nov 15, 2008
  • monk3ybidzness
    monk3ybidzness Nov 15, 2008
    One more thing, having your printer repaired costs more than buying a new one. Ask for quotation and compare the price.
    Genius:
  • 1,913 Answers
Press your cartidge in bottom side with some pressure.then pull it.
    Genius:
  • 1,124 Answers
Due the description of your problem you have to reset your printer. If still doesn't work the printer need to be serviced.
Posted on Nov 12, 2008
    Brigadier General:
  • HP Master
  • 3,614 Answers
To avoid further damages - the printer now suffering a mechanical problem & its better to bring the printer on service instead of getting the luck for you to fix it, if you have no idea how to repair such one.
    Master:
    Sergeant:
  • 449 Answers
Hi1
try to removed the cartridge or unscrew if
those have then try to move the cartridge socket
or put oil on the gear that the cartridge will move
smoothly
    Genius:
  • 1,550 Answers
  • Remove ALL ink cartridges and close all covers
  • Unplug power cord from back of printer
  • Wait 10 minutes
  • Plug power cord back
    Sergeant:
    Novelist:
  • 196 Answers
Ok.remove the power cord.and try to move the cartridge holder by your hand and bring them to the center.than on the printer.
  • mmechanics Nov 12, 2008
    when you open the door of the printer you will see a steel colour  rod in the printer on which the cartridge carriage holder moves.if that steel colour rod becomes rusty at the ends the carriage is unable to move properly and it gets stuck in the corner.so OFF the printer.pull the cartridge holder with your hans it will easily get moved.apply any soft greese material on that steel rod and with your hand move the carrisge holder on that rod.if will become fluent and then never give u such types of problem again.for a longer period of time.
    feel free for further assistance.
    thanks,
  • HP Master
  • 6,487 Answers
You need to take the cartridge out again then put it back in make sure cartridges are properly inserted ...
  • Mark Gil
    Mark Gil Nov 12, 2008
    If the cartridge is stuck the next thing you need to do here is to take the printer apart so you can remove the stuck cartridge and also check for any mechanical failure of the printer...
    Genius:
  • 1,847 Answers
Take the cartridge out and reinstall it.
  • Legin Varghese
    Legin Varghese Nov 12, 2008
    turn off the printer by unpluging the printer and plug back and check if the cartridge comes back to the center.
    if not manually pull the cartridge to the center and power cycle. then reinstall the cartridge.
    this should work.... let me know you need further assistance...Kevin
  • HP Master
  • 19,396 Answers
Try first unplugging power cable for ten minutes.
  • Ginko
    Ginko Nov 12, 2008
    If that does not work try pressing the on button for ten seconds.
    Try also removing the cartridge.
    Then unplug power.
    Put back cartridges in place.
    If it stays stuck try gently playing with the ink carriage, if it does not unlock, then there is a fault in the mechanic, the motor or the traction belt are broken.
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
Problem installing drivers for HP 4355 printer in vista 32bit OS
Vista OEM Cd usually doesnt come with drivers.
Printer should have come with its own cd which contains both the software & drivers.
If it didn't come with any
You can try using windows update
or
downloading drivers from hp site
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=en&product=1138373&lang=en
Feb 24, 2008 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
27 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
