Question about Viking VGRC605-6 Gas Kitchen Range
Ovens wont light , glow bars work both ovens wont light
Both ovens quit at once, glow bars work , power to valves, top burners work.mThanks
  • feam Nov 12, 2008
    Thanks didnt know it needed 3 amps, ill check. I still find it hard to belive that all 4 ignitors went at once. Do you know where i can buy them. Thanks again, Greg
  • 60 Answers
The problem is the ignitor or both of the ignitors are not working properly remember just because they glow doesn't mean they are good they have to draw at least 3 amps to open the gas valve if not they will glow all day let me know how you make out
Posted on Nov 12, 2008
  • Joe Potter Nov 12, 2008
    they work in sseries if one doesnt go then the rest wont you have to seperate and measure each one seperately or the next ignitor will screw up the amperage reading and you should be able to go to any appliance parts store to purchase them
I have a GE Kitchen range XL44, stove top burners work fine, but oven won't light??? HELP please
Unplug the range.
Remove the oven racks.
remove the oven base pan.
remove the flame spreader pan.
remove the glow bar ignitor on the left hand side of the gas burner and replace it with a good ignitor.
Jan 25, 2010 | GE Kitchen Ranges
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Lights once then not again
    Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
    This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
    Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
    Kenmore gas range model # 362.7121191 oven
    Could be the thermostat, glow bar, valve or wiring but usually the glow bar
    Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
    ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
    Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
    Broiler glow bar stays on
    the glow bar stays on in gas ranges the whole time the cycle is running if it didn't the safety valve couldn't open its normal
    Jan 20, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
    GE XL 44 GAS OVEN
    there is an ignitor called a glow bar in the oven if its gone bad or just gotten weak the saftey valve wont open to let gas in so it wont be able to light. replaced the glow bar
    Nov 26, 2007 | GE JGBP28 Gas Kitchen Range
    Electric starter gas oven model jgrp17 won't heat
    more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
    Nov 13, 2007 | GE JGRP17 Gas Single Oven
    Ge Spectra
    Remove the bottom of the oven you will see 2 screws in the back. once you do that there is a flame baffel on top of the burner held on my one screw. remove that. now turn the oven on and watch to see if the glow bar comes on. I would say it wont or if it dose it is to weak to open the gas valve. Replace the glow bar and you will be back in business. the glow bar is a ware item everytime theoven is on and is heating the glow bar is on . good luck
    Jul 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Viking VGRC605-6 Gas Kitchen Range Logo
    233 people viewed this question
    Top Viking Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
