Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Machine keeps stopping
My wdm73 keeps stoppoing. Sometimes is say E11 - check water supply and after resetting it would say e15 - check outlet pipes.
Any advice would be useful.
Thanks
Adam
  • 43 Answers
If its right at beggining of wash could be pump blockage chack for coins or ffluff blocking filter
Posted on Nov 12, 2008
Turned on electrolux washer while cold water was disconected. Now receive an E11 error. Have reconnected cold water machine will not reset
Make sure the cold tap is turned on properly - sometimes the handle moves, but the shaft does not turn - especially those blue plastic ones. E11 means no water supply. Turn the shaft on the tap with a small spanner if necessary - make sure water is flowing.May be blocked with limescale - or the filter in the tap bunged up. Or could be problem with cold fill valve on the machine I suppose - wire disconnected, or needs new valve. Can you hear the valve buzzing when you start the program and it should be filling? check water supply again. take hose off the machine, turn tap on and see if water flows, with pressure.
Sep 15, 2017 | Electrolux Washing Machines
How do you fix e11 code?
Hello friend, thanks for your post!
I see that your Electrolux washer is giving off an "E11" error code. An "E11" stands for water is not entering, which can be several possibilities. The water supply to your home has been interrupted or water pressure may be low. Check the hoses to assure they are not kinked and the drain pipe is proper per installation. If these steps have not resolved your issue it could be a problem within the control panel and I would perform a reset on your appliance, which is disconnecting power from it for roughly ten minutes. Hopefully this helps. -Matt
Sep 06, 2014 | Electrolux Washing Machines
E15 during a wash
'E15 Check outlet pipes
check the filter and all pipes and there are no blockages
Feb 10, 2013 | Hotpoint Washing Machines
On my Haier HWD1000, I keep getting error message E11... what does this mean?
Error E11 means either:
The water level can not
reach the reset water level
within 5 minutes
OR
reach the setting water level
within 8 minutes
What this means is check your water supply for sufficient pressure and if for some reason it stops and starts (eg. well drawn water with a small reservoir sometimes.)
You may have to make sure that there are no other water uses going on at the same time.
Jun 21, 2010 | Haier HWD1000
I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Please rate my solution.
Thanks.
Jan 19, 2010 | Washing Machines
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Hotpoint MODEL WM75PR error code E15
E15 "Check Outlet Pipes". Normally this is a blockage in the pipe or the filter connected to the drum.
Error code 15: Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not
blocked.
What you need to be sure of, is whether when the error telling you to check for blockages in the outlet pipes happens, it's actually an accurate indication of the fault. I dislike these stupid error codes as they often fire off erroneously and cause no end of trouble.
It can also mean a faulty control panel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 09, 2009 | Washing Machines
Do anyone know what e11 mean on hotpoint wd71 pls
It means "No hot/cold fill" and recommends - Check the water supply, inlet valve and hot and cold hose connections.
Mar 27, 2008 | Washing Machines
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
256 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
