Question about Philips 9P5034C 50" Rear Projection Television
Blurry picture I purchased a TV 3 years ago. Since I purchased this unit (Philips 50" rear proj.) it shows blurry picture. It looks like it is getting worse. Does anyone have a solution for this. I moved it from place to place in the house because of window light but the problem still there and I'm getting sick of it. Is it the end of this unit or can this one be fixed
  • wayne1948 Dec 31, 2008
    i can not adjust my color my picture is red
  • Philips Master
  • 3,459 Answers
The CRT fluid in the blue and green tube are most likely clouded. The set is still good. You just need to replace the fluid. Check with the site www.TvRepairkits.com - they are working on developing a fluid kit that includes a photo instuction quide.
Posted on Dec 08, 2008
9P6034C 60-inch rear proj TV = works great but beginnng to have picture "yellow-out" - kind of looks like brown-&-white photo - especialy at first, then perfect picture. This has gradually...
Coolant in crts needs changed. May not be cost affective. You need special equipment and much skill. If you can find servicer that can do it ask them before you schedule the call for what thie wouls cost. I would charge around $350.00. Go view a new set at 1080i and it this set at it;s best is not even close.
Aug 30, 2011 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P5031C 50-Inch Projection TV has a red/orange blur the whole picture is blurry
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 04, 2011 | Philips Magnavox 55P9271 55" Rear...
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Philips 50" rear projection- Washed out picture.
You need to change the CRT Fluid. This is a common problem on the  older projection TV sets.
You can get the fluid and instructions on how to change it from www.TvRepairKits.com.
Dec 19, 2008 | Philips 9P5034C 50" Rear Projection...
Blurry partial picture on a 42" rear proj tv
There may be dust on Lamp or at front screen. why dont you open rear cover of TV and give a close look?
May 28, 2008 | Sony KP-51HW40 51" Rear Projection...
Blurry/Hazy picture on Philips Tv
as your problem is the picture has become blurry/hazy 1 it sounds me that there is a little sparking near high voltage section that is near flyback transformer.please get it check. 2 if it is ok then focusing anode wire going to crt base from flyback transformer is not making proper contact due to some foreign material deposited on it. please call tech person if you ae not aware of it as tv is a very high voltage device.
Oct 01, 2007 | Televison & Video
Red picture cannot adust with convergence
You have bad CRT Fluid, the green and Blue tube need the fluid changed. This is a messy and possibly dangerous to the tv proposition, you will want to call someone to change the fluid, you will probably spend $450+ for the repair, but it should look pretty good when done, possibly better than it has looked in years.
May 27, 2007 | Philips 9P5034C 50" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
