Question about True TD-95-38-LT Beverage Cooler
Door light the wiring for the glass door light is to short for connection at bottom of door
Power window wiring diagram for 1998 Lincoln town car
Go to http://bbbind.com/free_tsb.html free wiring diagrams !
  • Power Windows Completely Inoperative
  • Window regulator control switch.
  • Circuits open or shorted.
  • Window regulator electric drive.
  • Driver door module.
  • PERFORM Self Test to retrieve Diagnostic Trouble Codes. If no DTCs retrieved, GO to Pinpoint Test C .
  1. VISUAL INSPECTION CHART
  1. Mechanical
  2. Electrical
  • Front door power window regulator damaged.
  • Front window run damaged.
  • Front door window glass out of window run.
  • Front door window glass broken.
  • Lighting control module.
  • Circuits open/shorted.
  • Loose, corroded connectors.
  • Damaged window regulator control switch.
  • Damaged window regulator electric drive.
  • Power distribution box Fuse D 40 for heated back window concern; Circuit Breaker 14 (20A), Circuit Breaker F (30A) or window regulator safety relay for power window concern.
  • Fuse junction panel Circuit Breaker 14 (20A), Fuses 6 (10A), 9 (5A), 15 (15A), Fuse 13 (10A), Fuse 4 (10A) or Circuit Breaker 12 (18A).
  • Scratched grid.
  1. If the inspection reveals obvious concerns that can be readily serviced, correct the concern before continuing with Inspection and Verification.
  1. If the concern remains after the inspection, connect the Rotunda New Generation Star (NGS) Tester, 007-00500 or equivalent, to the data link connector (DLC) located beneath the instrument panel to perform DATA LINK DIAGNOSTICS test. If the NGS responds with NO RESPONSE/NOT EQUIPPED for the driver door module, go to Pinpoint Test A . If the NGS responds with NO RESPONSE/NOT EQUIPPED for lighting control module, go to Pinpoint Test B . If the DATA LINK DIAGNOSTICS test is passed for the driver door module and lighting control module, retrieve continuous DTCs and execute self test diagnostics for the driver door module and lighting control module to retrieve current DTCs.
  1. If self test is passed and no DTCs are retrieved, go to Symptom Chart to continue diagnosis.
  1. If DTCs are retrieved for the driver door module, go to the Driver Door Module (DDM) Diagnostic Trouble Code (DTC) Index to continue diagnosis. If DTCs are retrieved for the lighting control module, go to the Lighting Control Module (LCM) Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If the driver door module cannot be accessed by the NGS tester, go to Pinpoint Test A . If the lighting control module cannot be accessed by the NGS, go to Pinpoint Test B .
Rotunda Service Bay Diagnostic System (SBDS®) 001-00001 may also be used to diagnose this system.
You'll need more then wiring diagrams ! A good scan tool for starters .
Youl
Aug 08, 2016 | Lincoln Cars & Trucks
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
1996 Mercury Mystique Window
Here are the instructions:
    • Gently remove the door panel of your Contour, ensuring that you don't break the three door clips that hold it on. As you pull the panel from the door, support the panel from below. This will ensure that none of the wiring inside the door is damaged. Release the wiring from the components inside the door, including the power window mechanism, power lock mechanism (if equipped) and the stereo speaker. Place the door panel in a safe area with the clips so they are accessible when you are ready to replace them.
    • 2Remove the window glass by sliding it up and out of the door. Support the glass from the bottom so it doesn't drop and break. Window glass for a Contour can cost around $150 to replace. After you remove the glass, put it in a safe place. You may want to wrap it in old towels or blankets to protect it until you are ready to reinstall it.
    • 3
    • Unplug the wires from your Contour's window motor, and remove the screws from the window motor and regulator. Remove the power window motor and regulator from your Contour to make way for the new parts.
    • 4Install the new window regulator into the door, and replace the screws that held them in place.
    • 5Replace the window glass into the door, and connect it to your Contour's power window motor and regulator assembly.
    • 6Replace the door panel. Reconnect the wiring for the power window and power lock controls, and replace each clip that connects the panel to the door.
Jul 26, 2012 | 1996 Mercury Mystique
How do you replace front drivers side window motor 1997 mercury mystique
The motor and regulator need to come out here is how to do that.
Instructions
    • 1Gently remove the door panel of your Contour, ensuring that you don't break the three door clips that hold it on. As you pull the panel from the door, support the panel from below. This will ensure that none of the wiring inside the door is damaged. Release the wiring from the components inside the door, including the power window mechanism, power lock mechanism (if equipped) and the stereo speaker. Place the door panel in a safe area with the clips so they are accessible when you are ready to replace them.
    • Sponsored Links
    • 3Unplug the wires from your Contour's window motor, and remove the screws from the window motor and regulator. Remove the power window motor and regulator from your Contour to make way for the new parts.
Jul 01, 2012 | 1998 Mercury Mystique
No water or ice through the door, but still makes ice. All other controls work.
Check the switch on the door that is pressed when you want ice or water. Is it safe to assume ice and water are dispensed using the same 'button' for both? I have seen on some models that the switch is activated whenever you push a glass/cup against a 'soft' pliable area. If it were my problem, being the do-it-yourselfer that I am, I would find the wiring harness connection point for at portion of the door, remove the connector and touch a jumper to the connector wires to see if the switch is bad. A switch works by closing (shorting) two contacts together and the typical door switch, in this case, is a momentary closure switch.
Feb 22, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
1999 volkswagen bora 1.4 petrol ,central locking will not work at all with key on drivers side but locks all doors including drivers door from passengers side
My 1998 passat does the same the other way around.Does the courtesey light on the bottom of the door work?, if not then it's a brown wire going to the courtesey light(the thicker of the 2) that has a break somewhere.I ran a short test lead(earthed to the body if i remember) to this direct and everything worked like new but the light would remain lit all the time with the door closed.These wires are all interlinked with the windows/central locking/door switch/courtesey light and forced door entry(not breaking of glass).The lazy way is to run a link like i did and remoe the bulb but get a auto electrician to advise you first.
Jan 06, 2010 | 1999 Volkswagen Passat
How to change out a window regulator on a 2003 town and country
First you have to remove the door trim there may be screws by the inside door handle and the armrest that have to be removed, also at bottom of trim. Once you have unscrewed the door trim pull trim away from door and undo all electrical connections neccessary. In some vehicles removal of the speaker may be required. Remove insulation material affixed to door to allow access to door cavity. You will need to wedge, tape glass to keep from falling. Remove bolts that hold window regulator to door and glass some of the newer Chryslers may have a locking clip that hold window to regulator remove and separete from glass. remove regulator to the opening and install new one
Oct 22, 2009 | 2003 Chrysler Town & Country
How do I remove and install a rear passenger side window (manual) in a 1997 Saturn SL1?The window was smashed, and I need to replace it. Thank you so much for your time and help!
Saturn Coupes/Sedans/Wagons 1991-1998 Repair Guide
Door Glass and Regulator - REMOVAL & INSTALLATION
(see Figures 1, 2, 3 and 4)
  1. Remove the outer door panel assembly. Refer to the sub-procedure under Door Locks, earlier in this section.
  2. For rear doors, loosen the bottom fastener of the rear door stationary window assembly, in order to provide clearance, then apply tape to the lower half of the outboard exposed portion of the stationary window channel. The tape must be applied in order to prevent damage to the paint surface.
  3. Lower the door glass, then use SA9148B, or an equivalent tool, to remove the glass nuts. Push the glass upward and rotate slightly, then remove the glass from the vehicle.
  4. If the regulator is also to be removed, proceed as follows:
    1. Remove the inner door trim panel. Refer to the procedure earlier in this section.
    2. If applicable, unplug the wiring harness from the power regulator.
    3. Except for the rear door, remove the regulator cam bolts.
    4. Drill out the regulator rivets and remove the regulator from the vehicle.
To install:
  1. If removed, install the regulator to the door assembly:
    1. Position the regulator to the door and secure using rivets.
    2. Except for the rear door, install the cam bolts.
    3. If applicable, connect the wiring harness to the regulator.
    4. Install the inner door trim panel to the vehicle.
  2. Install the door glass into the door and over the regulator studs.
  3. Install the glass nuts using tool SA9148B, or equivalent.
  4. Check the door glass for proper operation and alignment.
  5. If necessary, adjust the glass alignment. For rear doors, fore/aft adjustments are made after loosening the B bolts, while in/out adjustments are made when the A bolts are loosened.
  6. Except for the rear doors, glass which is not running parallel to the door header may be adjusted after loosening the inner panel cam attachment bolts and adjusting the cam. If the glass is floating in the opening, lower the glass 3 / 4 downward, loosen the front guide fasteners, push the glass rearward to seat it in the rear channel, then bring the front glass guide back to the front edge of the glass. Apply a light finger pressure on the guide and tighten the fasteners.
  7. Once the glass has been properly adjusted and is operating smoothly, install the outer door panel assembly.
Fig. 1: Remove the glass nuts using a suitable tool-front door shown
Fig. 2: Exploded view of the regulator mounting-except rear door
Fig. 3: Exploded view of the rear door regulator mounting
Fig. 4: Adjustments of rear door glass are made after loosening the A or B bolts
I hope help with this (remember rated this help) Good luck.
Oct 16, 2009 | 1997 Saturn SL
How do you replace a drivers side window on a 1992 Saturn
See Figures 1, 2, 3 and 4
To install:
PICTURES ON NEXT POST!
Oct 13, 2009 | 2000 Saturn Ls 4dr Sedan
Exterior glass trim on Kenmore Electric Range 880-5981
While waiting for someone else to answer my question, I fiddled around with the door parts. I managed to reassemble them! Here's how:
1. start with the glass panel. Slide the glass panel into the slot at the bottom of the front door frame on the stove.
2. next attach the handle. There are slots on the bottom of the handle that fit into the top of the glass panel. Slide the handle slots into the top of the glass panel.
3. screw the handle onto the oven door using the predrilled holes on the inside face of the oven door.
4. last, attach each of the two side trim strips. Slide the top of each strip into the bottom of the handle on each side of the oven door. Then slightly bend the strip outwards so that they are short enough to fit into the bottom slot of the oven door frame on each side of the glass panel.
Jan 22, 2009 | Kenmore 45062 / 45069 Electric Kitchen...
True TD-95-38-LT Beverage Cooler Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
