Question about Vizio L32 32 in. LCD HDTV
No audio from tv to home theater
I have a 26in. vizio lcd tv and a sony home theater . I hooked up the hdmi but I don't get audio from tv to home theater .It's like no output from tv . It's all new I got it two days ago
Dana from mass.
  • 124 Answers
At the back off tv there is a connection labelled audio output you need to connect that to any available iput of your home theater receiver then use that for tv watching
Posted on Aug 15, 2009
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Jan 23, 2016 | Samsung Audio Players & Recorders
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Watching T.V. with speakers
Component 1 on the TV is probably an input, not an audio output. You need to find out if your TV has audio output jacks.
If I'm mistaken, and you are using audio output jacks from the TV, then you just need to press FUNCTION on your remote until the LCD display says "TV/VCR".
Apr 28, 2008 | Sony DAVHDX265 System
Home Theater System
YOU HAVE TO CARRY THE SOUND FROM YOUR SKY BOX OR CABLE BOX ETC,INTO YOUR SOUND SYSTEM,THEN INTO YOUR TV
Dec 29, 2007 | Audio Players & Recorders
Vizio L32 32 in. LCD HDTV Logo
134 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
