Question about Vizio L37 Television
VCR/DVD combo connecting to HD TV
I have a fuzzy picture when using the DVD player. I connected the standard red yellow and white cables. That picture was bad. I upgraded the cables to the blue,green, and red. That seemed to help, but the DVD only displays 480 instead of the 1080 on regular TV. I didn't have this problem on the other HD TV. I'm stumped !
  • 579 Answers
If the DVD player or HD tv doesnt upconvert to 1080i, then you are stuck with the native resolution.
Posted on Nov 16, 2008
How do I connect old school dvd/vcr combo to LED HDTV?
The general rule of thumb is that R-W-Y outputs from the VCR/DVD combo plug into corresponding color coded inputs on the TV. I think the Y(ellow)/VIDEO designation indicates where to insert the Y cord. It's worth a try.
Feb 12, 2016 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Using your DVD-V4600, how do you play a vhs tape on TV? Need step by step instructions.
In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
  • You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
  • use either "RCA analog (red/white +yellow ) " or "SCART "or "Optic " cable.(any standard optical cable )...if exist ,optic is the best way to connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
  • pls also remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have a 1994 zennith TV/VCR COMBO I am trying to connect a dvd player to. I have one yellow video cord and one double stranded audio red/white cord. I can not get a picture. Vcr player does still work.
Connect yellow from DVD to TV. Connect white and red cables from DVD to TV. Yellow to yellow, white to white etc. Then select on the TV using the remote, the proper input (where the DVD is connected) Press PLAY on the DVD player.
Aug 19, 2010 | Zenith Televison & Video
Need wiring diagram to connect to Philips HD TV
On the back of combo, use the side that says DVD and VCR out. Connect red, white and yellow cables from the output on the combo to the input on the tv. Use the tv remote and switch input of tv to where you plugged it in.
Aug 10, 2010 | Samsung DVD-V4600 DVD Player/VCR
No picture when I play back on vcr
Are you using AV connections(Red, Yellow, White) cable connections? If so The video connection may have come loose.
Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
Yes, To change the input to video jacks, you must change the channel to 00.
Jun 25, 2006 | RCA F27645 27" TV
Vizio L37 Television Logo
168 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
