Question about Philips HTS3450 System
Volume control we lost our remote and have tried some univerial remotes for the hts3450 but cant get the volume to work.  we can manually adjust but then whats the point of having a remote.  Sugestions please.
  • smg0413 Nov 16, 2008
    I have the same problem... I am trying to set this up with my Direct TV remote.
    You can get the power to work, but not the volume
  • 4 Answers
I know this isn't the best solution, but my Logitech Harmony 720 remote controls my hts3450 just fine (volume included).
Posted on Apr 28, 2009
Is there a manual volume button on the tv???? I dont have a remote controll, and cant raise the volume..
On the MX 3000 I don't believe there is a manual volume control. Sorry. Can you source a remote? A universal remote such as 3 in 1, may work.
Nov 27, 2014 | Televison & Video
We have also lost the manual for the RCA DTA800B1 converter box and need instructions to program the remote to work with a Sharp TV.
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sep 16, 2011 | Televison & Video
My olevia tv's volume is not working correctly. I
Maybe the remote or the tv manual control board is damage?Check the tv manual vol + - see if function normally.Take the remote aparts and clean it with some Q tips dip in with rubbing alchahol clean the remote PCB.Try website like Remotes.com to buy an exact to the original remote tv.
Jul 15, 2010 | Olevia LT27HVX 27 in. LCD Television
Just bought one of these used and need to adjust the color brightness contrast etc. I assume I do this thru the "menu" option. I don't have the original remote with the unit and I can't get any universal...
Try website like Remotes.com to buy the original remote it ur best bet.Tries the manual control on the tv.Push the Menu button use the channel + - and the volume + - on the manual buttons to adjust colors,contrast,brightness.
Jul 04, 2010 | GE 13TVR62 Combo
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
DEFECTIVE MANUAL VOLUME CONTROL ON SONY CMT-HPX10W
remove knob and use some pressurised air to blow out any scum thats built up. yes a remot would still work.
Jun 02, 2009 | Sony CMT-HPX10W CD Shelf System
I need to program a univerial remote for my aspire digital 5.1 sound system and cant find the codes can you help no spam please
some universal remotes dont work on newer model electronics call the manufacturer and see if they have any new codes for that unit
Dec 26, 2008 | Audio Players & Recorders
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
Jensen JR500 Remote Volume Control
Try reprogramming the codes into the TV for the volume control.
Jensen JR500 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps! DONT FORGET TO RATE ME on FIXYA!
Sep 04, 2006 | Jensen JR500 Remote Control
Philips HTS3450 System Logo
210 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
